Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-21-2003, 01:38 PM   #1
sq_geek
Question Slimline IDE Adapter - How does it work?
How the heck does this thing work??
My slimeline HDD has 44 pin holes and then 4 other pins to the side.
The adapter has the small end with 44 pins and plugs right in, but it says "pin1 (to HDD)" so I am sure it is installed facing the right direction.
The other end has 40 larger pins for normal IDE, but the IDE cable has 1 center pinhole blocked (normal IDE). Do I need to break that pin off (some of you call it a "security pin") from the adapter so it fits or what???
WTF?!?!
HELP!!
sq_geek is offline   Reply With Quote
Advertisement Sponsored links
Old 09-21-2003, 03:17 PM   #2
jol
jol's Avatar
jol is on a distinguished road
no manual? ask the store or makers
My cars
jol is offline   Reply With Quote
Old 09-21-2003, 04:32 PM   #3
sq_geek
I bought it off Ebay... They showed it plugged right into the IDE cable, but that is not possible unless I break off this pin. I'm sure it's OK, because it isn't hooked up to anything at the other end.
Old 09-21-2003, 06:33 PM   #4
Banned
outragis's Avatar
outragis
I had to do the same...It will work fine!
outragis is offline   Reply With Quote
Old 09-21-2003, 07:35 PM   #5
MeanGT's Avatar
MeanGT
I bought the exact same one also off eBay, just make sure you break off the right pin
MeanGT is offline   Reply With Quote
Old 09-21-2003, 11:46 PM   #6
sq_geek
cool, I did, and it works.
