10-27-2003, 07:05 PM
#1
Any way to relocate my display card??
Im putting my carputer in my car. I have the motherboard in the console and the console shuts fine, but once the display cable is plugged in it sticks too high to shut the console.
So I have a few options, either find a display cable that isnt as tall (the hard plastic at the end of it) or...somehow relocate the display card.
Now this is what i was thinking. If I could take a spare sound card or something, cut the connector that goes into the motherboard off it then solder wires from it to the connector on the display card, then connect the cut off connector into the board and relocate the display card wherever i likethink thatd work?or is there such thing as a lower profile display cable?
10-27-2003, 07:15 PM
#2
Yeah, you could do that. It would just take some work.. Try removeing the sheath on your video cable first tho, might be easier.
1993 BMW 325is - 15.2sec
10-27-2003, 08:00 PM
#3
I'm sorry, and you are....?
No it won't work, and if you don't want to fry your board and video card, I would not attempt it.
Video cards are dependent on timing, extending the pci or agp connection beyond spec is a bad idea.
[H]4 Life
I'm a lesbian too.
I am for hire!
10-27-2003, 10:18 PM
#4
Nevermind, I flipped my motherboard upside down and it seems there was enough room for the display cable underneath the console..
10-28-2003, 01:13 AM
#5
If youre talking about chopping a sound card that means your video card is PCI. You can get PCI relocator riser on a ribbon cable. They can extend out 2 inches.
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
10-29-2003, 02:30 AM
#6
Oh ****, sorry. I gave bad info!!! Yeah, frodo is right. Do not try this, I had thought you ment the video-out, not the PCI socket!!
12-26-2003, 03:26 AM
#7
You can extend the PCI to a point. It's included in the spec. Think how far the signal travels from the chipset to the socket, and how many sockets some boards have. I have an Epia with the soundcard relocated under the motherboard via a 5cm ribbon extender, no problems at all. This is a standard part for rackmount cases which can't even take low profile PCI, and turn the cards right-angles. They call them PCI Riser cards and you can get them various places. Mine's from mycableshop.com
But you found another solution anyway..
89 Celica, CarPC installed, 1st bday :)
http://www.fishy.net.nz/carpc/- MediaEngine
- Epia V8000
- 80GB WD 7200RPM HD
- Xenarc 700TS
- SB Live
- Opus 90W
- CIMR100 remote
- Deluo serial GPS
- D-Link USB radio wired to power antenna
12-26-2003, 07:54 AM
#8
pci relocator. the best you can get
http://www.gtweb.net/j1100.html
12-26-2003, 08:26 AM
#9
they have one for AGP cards too, I'm getting one for my Radeon to mount it parallel to the motherboard
12-26-2003, 12:18 PM
#10
Quote: Originally Posted by churnopol
Dude! That's the bomb. I am all over that.
THANKS!
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
03-21-2004, 10:57 PM
#11
what is this stuff about not having a slot in position b? does it have to do with bus timings? i'm looking at this card: http://www.rackmountpro.com/productpage.cfm?prodid=594 will it work for an EPIA-M? thanks.
ray
03-21-2004, 11:32 PM
#12
i would custum make a short VGA male to female cable with a low profile. i did it for a project befor when i needed more room.
03-22-2004, 09:29 PM
#13
i like the cases that are <3in high, but i really want 2 pci devices (audigy 2 and tv/fm tuner) and a decent agp graphic card. this would mean relocators for agp + 2 pci. not sure if this would work, especially since i would have to drill holes all over commercial case for openings for card outs. ideas anyone? probably microatx. how about just 2 cards?
03-22-2004, 10:14 PM
#14
Go with ATI All in wonder card. Great AGP performance and has built in TV Tuner. Mine works great.
Batman
Batman@TheNewBatcave.com
AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
www.samshomepage.net
www.Cars-N-Computers.com
| Thread Tools |
| Display Modes |
Linear Mode
