Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 12-11-2003, 05:28 PM   #1
Ren77 is on a distinguished road
USB power & touchscreen issues...
Hi!
I have a hp f1064a power supply running a m9000 in a cubid 3688.
Everything works fine...until I plug in the touch screen..and then the power supply cuts out...
I suspect it's drawing too much power through the USB socket and consequently tripping the PSU protection circuitry.
Would it work if I switched the 5v source that the touchscreen usb cable is drawing from? (ie use the 5v line off the ps2 port) or could I try a serial to USB convertor? would that be any better than using the standard USB port?
Many thanks,
Richard O'Donovan
Ren77 is offline   Reply With Quote
Old 12-11-2003, 05:56 PM   #2
MeanGT's Avatar
MeanGT
you could try an externally powered USB hub, but then you would need a 120v source I think,,
My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
MeanGT is offline   Reply With Quote
Got my TM-710VGT today...touchscreen issues: -al- LCD/Display 8 10-29-2003 11:00 AM
DS700TS-USB 7" USB Touchscreen VGA Finally! $375 dscustoms Classified Archive 4 10-13-2003 09:53 PM
Non-working touchscreen - USB Diagnostics tool? GingerPrince LCD/Display 2 09-15-2003 05:06 PM
HELP! USB HUB FOR Laptop, how do I power it??? bankingdom General Hardware Discussion 2 05-21-2003 07:33 PM
Sorting out power issues MattW Power Supplies 6 07-16-2001 04:41 PM
