The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 09-26-2005, 02:33 PM   #61
TheLlama's Avatar
Vehicle: 2001 Paper Airplane Standard Edition
My Photos: (0)
I just scanned this thread real quickly but I didn't see anyone mention this: adding shocks like you mentioned may actually be a bad idea. If they are too spongy then it will cause the drive to bounce up and down with more magnitude then it would if it was securely mounted. From my understanding, drives are better at handling alot of small vibrations than a few large ones. In addition, your car's suspension and shocks should do most of this work for you. Unless of course your drive is floating like you suggested (which will just cancel out any gains from your car's suspension).
TheLlama is offline   Reply With Quote
Sponsored Links
Old 09-26-2005, 02:39 PM   #62
deadweasel's Avatar
Vehicle: 2004 Mecury Marauder
My Photos: (0)
Amen. There's no need for all the extravegant overthought that's going into the subject.
Another thing: a floating drive could be a bad thing, depending on the material used to suspend the drive. If it's springy like a bungee cord, the drive could just sit there boinging around, and that's a really bad thing. The drive could oscillate long enough to cause some damage along the line...
The ALEXIS Project
MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
Color Coding :
DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
deadweasel is offline   Reply With Quote
Old 09-26-2005, 07:04 PM   #63
Banned
RPM_VR4's Avatar
Vehicle: 3000GT VR4
My Photos: (0)
The same stuff keeps getting said over and over. None of it is what I am looking for.
Does any one have a link to any tests performed or scientific analysis regarding the a HDDs life, chance of corruption, or likeliness to "skip" while playing an MP3 when mounted flat vs. parallel to the wheels? (I'm talking hard-mounted only... I do not care about shock-absorbing, I care about mounting orientation.)
I use a PhatNoise DMS in my CarPC which is a laptop HDD and it has rubber end-caps. I am not worried about my drive. I am curious if there is any scientific data concerning if it is "better" to mount it parallel to the wheels or not.
RPM_VR4 is offline   Reply With Quote
Old 09-26-2005, 07:26 PM   #64
TheLlama's Avatar
My Photos: (0)
It probably isn't too important. However, common sense tells me that mounting vertically will reduce the chance of a "head slap". Also consider this: I had a 3.5" desktop harddrive installed in my original MP3 system (around 1999). I rode with the unit for over 3 years. The drive was mounted flat (horizontally). Also, the case containing the drive was not mounted at all. The drive slide around and bounced against my trunk all the time.
I was then in a serious car accident. My car rolled twice and hit two telephone poles. I was able to retreive all my music off the drive. Call it chance.. but I think everyone is too concerned about this.
Old 09-26-2005, 07:42 PM   #65
Vehicle: 1998 Subaru Impreza RSTi Type RA
My Photos: (0)
It doesnt matter if the drive oscilates or bounces further, in fact, that's what you want.
It's the single hard shock that is bad for the drive.
Splinter is offline   Reply With Quote
Old 09-26-2005, 09:09 PM   #66
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (29)
No. They don't. This comes up over and over and over and all anyone ever expresses is opinion and anecdote. No facts.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is online now   Reply With Quote
Old 09-26-2005, 09:10 PM   #67
Raw Wave
TruckinMP3's CarPC Specs
TruckinMP3's Avatar
Vehicle: '02 suburban with quad captain seating
My Photos: (0)
no hard facts. But splinter is not accurate.
Bouncing or more motion is bad.
Mount the drive firmly to the chassis of the auto. Mine survived a frame bending wreck.
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 09-26-2005, 10:16 PM   #68
Banned
RPM_VR4's Avatar
Vehicle: 3000GT VR4
My Photos: (0)
...bouncin' ain't bad. I got a 15000 RPM drive on ma' speed-boat and it don't hurn none.
LOL.
Old 05-16-2006, 08:04 AM   #69
My Photos: (0)
Once again, opinions rule, so IMO;
Horizontally would be top priority.
Then vertically.
It's really a matter of trial and error.
And it all depends on the user's vehicle/driving style/driving conditions.
However, I shall be doing none of these.
I'ma keeping my methods and what-not, a secret.
Un_discovered is offline   Reply With Quote
Old 05-16-2006, 10:20 AM   #70
deadweasel's Avatar
My Photos: (0)
Yeah,
There are no true hard facts when it comes down to something like this, because in most cases, there really isn't a whole lot of difference in how a particular mount affects a hard drive's operation in a car, plus, not too many people are willing to risk personal injury or damage to their car to get the data.
Steady, continuous oscillations of the drive are generally a bad thing, but otherwise, vertical/horizontal mounting isn't going to make much difference, unless you drive like Tron or Automan, (90 degree turns in a split-second).
Gyroscopic forces have a minimal impact in a vehicle-mount environment with almost all of today's vehicles, on most surface streets and highways. Even large potholes will have a negligible chance of causing damage, thanks to the vehicle suspension.
So now, since nobody has willingly subjected their car PC to the ultimate test, I hereby submit my own evidence.
I've mentioned this before, and it's the best I can offer as proof: a Quantum Fireball 20GB hard drive, running full-tilt in the trunk of my 92 Mitsubishi Eclipse GS, experienced a rear-end collision at about 45MPH. The drive was mounted horizontally in a desktop pc case, just sitting loose on the trunk floor.
After the impact, the drive had not errored one bit. Never a glitch during or after the impact.
In fact, the drive is still doing just fine as a storage drive in one of my house machines now. This happened about 6 years ago now.
Despite all the talk here about shock mounting and mount axis, all I had was a drive in a box that was free to move around the trunk if it had to (I hadn't gotten around to a mount for the case at the time), and lo, the drive survived an impact that was far greater than it would have ever experienced during normal driving.
There's your "study evidence". It cost me a sore neck for a week to get it, so I hope it comes in handy for you somewhere down the road!
The ALEXIS Project
Color Coding :
Sponsored Links
Old 05-16-2006, 11:28 AM   #71
Raw Wave
TruckinMP3's Avatar
My Photos: (0)
Holy old thread batman
09-26-2005, 09:16 PM
TruckinMP3
Read the FAQ!
Old 05-16-2006, 02:07 PM   #72
tom2112's Avatar
Vehicle: 2003 Mitsubishi Eclipse GT, 5spd
My Photos: (0)
What're you talking about? This thread started 12-21-2003!
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
tom2112 is offline   Reply With Quote
Old 05-16-2006, 02:10 PM   #73
Raw Wave
TruckinMP3's Avatar
My Photos: (0)
The gap from the last post before today.
TruckinMP3
Read the FAQ!
Old 05-16-2006, 02:21 PM   #74
tom2112's Avatar
My Photos: (0)
Yoiks, scoob! That's ridiculous.
For all you folks just joining us, allow me to recap:
The answer is No.
Don't bother with elaborate shock absorbing - vibration isolating - super duper wonder mounts. Just bolt the darn thing in your case and fuggidaboudit!
The other answer is: Can't say for sure.
There is no scientific or otherwise reliable data on whether mounting your drive horizontally or vertically will prolong it's life.
If you're very curious about this, I suggest you go buy two identical drives, mount on horizontal and one vertical, and mirror the drives so they both get the same exact usage. Then drive around with them in your car until one fails. Let us know which one it is.
There. Aren't you happy I saved you from reading this entire thread?
So far:
Old 05-16-2006, 06:04 PM   #75
Raw Wave
TruckinMP3's Avatar
My Photos: (0)
The answer is No.
The really goofy thing... you still will not be able to state the reason for the failure.... just that it died.
TruckinMP3
Read the FAQ!
Sponsored Links
vB code is On
Trackbacks are Off
All-electronic flash drive and solid state hard drive Typhoon747 General Hardware Discussion 12 12-12-2003 02:20 PM
Slightly different hard drive mounting question Tygur General Hardware Discussion 11 05-05-2002 02:52 PM
External notebook hard drive help mtmsol General Hardware Discussion 4 04-18-2002 12:24 PM
Mounting hard drive allstarme General Hardware Discussion 1 05-21-2001 11:07 AM
Idea to protect the hard drive... Szech General Hardware Discussion 9 01-29-2001 09:55 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
