12-26-2003, 06:33 PM
#1
Best mountable, DC powered USB Hubs?
I have an EPIA board and it only has two USB ports and with the ever expanding number of peripherals hooked into my computer I am in serious need of some USB Hubs. Several of my devices (USB HDD, USB 802.11b adapter, etc.) take up pretty much all the power that a single USB port can supply, so hubs that get their power from the USB port are not an option. I also am running off DC, so wall-wart powered hubs are not an option. I have managed to power several peripheral devices that would ordinarily run off bricks by using the +5 and +12 volt lines of the molex connectors coming off my power supply. Both of the USB hubs I have tried require unusual voltages (7.5 volts). So, anyone have any ideas on how I can get some powered USB hubs to work in my car? I would ideally like something that can easily be mounted.
12-27-2003, 08:44 AM
#2
Raw Wave
I have a USB2 hub which IIRC said it needed 6V. I hooked it up to my 5V from the PSU, and it is working, powering a USB GPS, and a USB2 to IDE adapter for my slimline CDROM drive
Check for some more USB hubs, there are some out there that run off 5ish volts
Garry
12-27-2003, 01:04 PM
#3
Raw Wave
I bought one off newegg that use 5v, but 2.4A!
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
12-27-2003, 01:14 PM
#4
off the shelf at comp USA I got a usb 2/1 that runs off of 5v DC. 1 inch square of velcro and dazam! 4 more usb ports.
12-27-2003, 01:57 PM
#5
12-27-2003, 02:57 PM
#6
Yes, I know that there must be some out there that work, but saying so doesn't help me any. If you have something that works reliably off the 5 of 12 volt lines of a molex connector, could I please get some brand/model numbers. I don't want to just go around buying USB hubs until I find one that works.
12-27-2003, 03:26 PM
#7
This is what I bought, works perfectly off my 5V line: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3054173165 . It has four hi-speed ports and is the smallest powered hub I could find for cheap. They are now 3M stuck in my glove box. Just search ebay for "Mini USB 2.0 HUB" and you'll find a lot.
I didn't know that they even made 7.5V hubs, that's is rediculous in my opinion. It must be regulated internally to 5V.
12-27-2003, 07:56 PM
#8
Have you guys checked this out ?? Seems like a cool idea, and with a little ingenuety you'd be able to mount or modify it not to expose the guts...
http://www.siig.com/product.asp?part...20-%20Internal
it seems to take power from a floppy drive power hookup...
12-27-2003, 08:28 PM
#9
thanks for the link. I wouldn't be suprised if closer inspection of that board reveals it to be using just the 5v or 12v... both good for what we're talking about :-)
12-28-2003, 12:48 AM
#10
I really like the looks of that one from siig, particularly that it takes a floppy connector. I think I saw one like that at Fry's once, so I will check there in the next few days.
12-29-2003, 01:22 PM
#11
If you look closely, the Picture shows the power adapter just to the left of the USB Square Uplink Connector...
12-29-2003, 02:51 PM
#12
Will this work, it sais it's powered via the USB Hub and has per port overload protection, but I wonder weather that hub would support say 4 Mobile USB2.0 DVD ROM drives... (Powered off the USB Port)  Not that I need that many but as far as power draw goes I wonder .... :scratch:
http://cgi.ebay.com/ws/eBayISAPI.dll...31495&tc=photo
Than again for under $10 ... we'll see...  And there's other auctions for that price too
12-29-2003, 03:24 PM
#14
Not directly related but I purchased on of these cables
http://linitx.com/shop/product_info.php/products_id/323
Its converts the mini-usb connector for the 3rd and 4th USB ports on the Epia MB into a normal MB connector. Its works a treat with the front connectors on the 3688 case I have meaning that I've now got 4 usb sockets all able to give out the full 500ma.
| Thread Tools |
| Display Modes |
Linear Mode
