The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 01-02-2004, 12:57 AM   #1
Vehicle: 1997 Honda Civic LX
My Photos: (0)
Basic electronics question...
Ok, so I'm not the smartest guy in the world, but I don't think I'm retarded, and I just want somebody to verify this. I am in the process of building a new case for my carpc. (http://www.mp3car.com/vbulletin/showthread.php?t=19858) anyways I'm installing some LED's into them right now and I'm going to use one of the 5V lines from the floppy power connector... now I screwed up earlier and just connected and LED directly to it.. thus burning it out. Now what I think I need to do is just go down to radio shack and pick up a 3V resistor.... am I right? just solder the 3V resister between the hotwire and the (+) portion of the LED?
Let me know thanx in advance
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Sponsored Links
Old 01-02-2004, 01:11 AM   #2
Raw Wave
Vehicle: 1992 Ford XR2i
My Photos: (0)
3V resistor? nonono.
What you need is to limit the current going into the LED. You can do this by adding a resistor in series with the LED.
Heres a typical setup :
2V voltage drop on LED (depending on colour/type)
15mA current to pass (depending how bright you want, dont exceed the limit)
5V supply
Check the datasheet for accurate values.
(5-2) / 0.015 = 220 ohms (the nearest E12 series)
The colour code (RED/RED/BROWN/GOLD) +-5% tolerance.
So put a 220 ohms 1/4 watts resistor in series with the LED...observe the A/K polarity of the LED, the flat side goes on the negative side of the supply.
You can get a 5V LED...probably easier for you
Ricky327 is offline   Reply With Quote
Old 01-02-2004, 01:40 AM   #3
My Photos: (0)
Any idea where? I've looked locally and all the LED's I've found online thus far are maxed out at 3V. by the way thanks for the quick response!!
Old 01-02-2004, 01:45 AM   #4
Raw Wave
My Photos: (0)
Dont know in US but Ill give you a UK site :
http://www.maplin.co.uk/products/mod...737&Products=2
The 3V LED you are talking about is the forward voltage, thats not the supply voltage. Any LED can be made to operate at any voltage (within reason) by adding the series resistor.
Old 01-02-2004, 01:53 AM   #5
jol
jol's Avatar
Vehicle: Audi 90 -88, VW Polo CAB -81
My Photos: (0)
www.lsdiodes.com has leds, bright ones too. and almost free shipping!
My cars
jol is offline   Reply With Quote
Old 01-02-2004, 02:01 AM   #6
Raw Wave
My Photos: (0)
Cant see 5V LED in there jol
Old 01-02-2004, 03:30 AM   #7
Raw Wave
Confused's Avatar
Vehicle: Honda Prelude 2.2 VTEC / Ford Anglia 105E
My Photos: (0)
Check out the LED calculator, which will tell you what size resistor you will need for the LED and supply voltage
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 01-02-2004, 01:06 PM   #8
cvi
My Photos: (0)
Connect two LEDs in series and connect it to the 5v supply. Thats the easiest way to do it without resistors. The leds should be same specs to use this, but you dont need resistors.
cvi
cvi is offline   Reply With Quote
Old 01-02-2004, 01:45 PM   #9
crosseye's Avatar
Vehicle: 1998 Dodge Stratus
My Photos: (0)
CVI, first of all, why would you connect two LEDs in series? Resistors are WAY cheaper than LEDs. Also, connecting a resistor in series with an LED is just as easy as connecting two LEDs in series.
Second of all, as far as I know, connecting two LEDs in series is not going to do anything to protect either LED. Kirchoff's Current Law implies that the current is the same through any number of components in the same loop (in this case, both LEDs in series). With two LEDs in series there is no significant impedence to limit the current. The only thing that's going to happen is the voltage drop across both LEDs is going to be equal to the sum of voltage drops across both LEDs in series.
My recommendation, throw a 230ohm-1Kohm resistor in series with the LED. If the brightness is not suitable, reduce the value of the resistor to increase brightness in the LED.
crosseye is offline   Reply With Quote
Old 01-02-2004, 02:15 PM   #10
Raw Wave
My Photos: (0)
Wait up guys, this is getting to complicated now
Ive already done the hard bits, even show whats the colour code of the resistor should be and even explain how to connect it all up, it cant be any easier than that
Sponsored Links
Old 01-02-2004, 02:45 PM   #11
SjLucky's Avatar
Vehicle: 89 Firebird Formula 350
My Photos: (0)
yea it can
it could be done for you...
"You anit leading but two things Jack and **** and Jack left town"
"Just When You Think You Forget About a Chick She Pops Up Like a Case of Herpes Simplex B"
Ask Me About Hubernate!
SjLucky is offline   Reply With Quote
Old 01-02-2004, 03:48 PM   #12
Vehicle: '02 Subaru WRX
My Photos: (0)
http://superbrightleds.com/
As the name implies, they have very bright LEDs
--Dima
heat is offline   Reply With Quote
Old 01-02-2004, 04:11 PM   #13
Registered User
Sh0cker's Avatar
Vehicle: mk3 GTI VR6
My Photos: (0)
since we are talking about LEDs here, i need some help locating online store that carries 3mm Red(high bright) 12V LEDs.
thx
Danny.
"If today was perfect, there would be no need for tomorrow."
My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
Sh0cker is offline   Reply With Quote
Old 01-02-2004, 05:09 PM   #14
cvi
My Photos: (0)
Sorry, i wont speak up again. BUT...
* He needs more leds connected. (read post)
* He asked for a 3 Volt resistor.
Since there are no such thing, the easiest to do are leds in serial. Power coming from the computer psu would give 5V, that makes 2,5 V for each led.
* He dont have to mess with calculators or make a fool of himself asking for a 3 Volt resistor.
* It will work.
Old 01-02-2004, 06:03 PM   #15
Vehicle: 1995/Chevy/Camaro
My Photos: (0)
* It will work.
I'm sorry to say, it won't work. An LED when conducting does not drop 2.5 volts. LEDs are misleading. They are CURRENT SPECIFIC not Voltage specific. The resistors aren't really used to reduce the voltage, they are used to limit the current. An LED will operate just fine with only 0.7 volts applied. The Spec on the LED of 3V is a MAX operating voltage, not a voltage requirement. Use the reistors. Or, if you wish, some LEDs are "pre-resistorized" to run TTL (5V) levels without an external resistor.
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
Jackso is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Your basic newbie question here. tlbuckingham General Hardware Discussion 7 09-16-2002 01:42 AM
Electronics question SuperMatty Off Topic 8 08-11-2002 02:47 PM
lcd power question jrbless LCD/Display 1 04-07-2002 12:27 PM
Do you work in te field of electronics??? THEMP3KID Off Topic 9 02-12-2002 09:02 AM
Another inverter question...for electronics gurus moahdib Power Supplies 10 06-07-2001 08:30 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
