01-06-2004, 09:29 AM
#1
Where to get com2 serial adapter for m1000?
Anyone know? Looking to use more then 1 serial device, thus I need the add on serial port which doesn't come with the m1000.
-Jason
01-06-2004, 09:35 AM
#2
FLA
Mine came from an old AT tower I had lying around, so most any computer shop would be a good place to look for one. Lots of old motherboards were like that.
Heres one for example: http://www.cables4computer.com/produ...roupcode=I0632
Google may not help too much, but try Froogle. It gives you items and prices and can be sorted.
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
01-06-2004, 09:45 AM
#3
Raw Wave
Any mom and pop computer shop will have a box full. Maybe a $1, $1.50 at the most.
01-06-2004, 02:39 PM
#4
good luck gettin it to work.. mine didn't on my m9000, but i almost suspect that my psu isn't powerful enough at the moment
01-06-2004, 02:49 PM
#5
Raw Wave
This correct to a degree. Some of the older ones used a diferent pin setup. I had a bad one before getting one that worked.
01-06-2004, 03:00 PM
#6
i see... i have no clue where i got my serial cable so that might be the problem, but i can't even power a notebook usb drive via the bus at the moment.
01-06-2004, 03:23 PM
#7
Raw Wave
I would try another serial adaptor before giving up on it.
01-06-2004, 04:16 PM
#8
just ordered an opus... we'll see if that fixes things as well
01-06-2004, 04:33 PM
#9
I am having sme problem with the pin config, can some one check and let me know
ALIBABA - I30 99
Nemiah M10000, C134
DVD, 40Gig, 256MB DDR
GPS, OBD 2, Reverse Cam
Mute on stereo w I300 car kit
Liliput 7in w usb touch screen
Direct connect with BOSE-CD changer
01-06-2004, 04:44 PM
#10
FLA
try this:
http://www.phm.lu/Documentation/Connectors/Serial.asp
Or are you looking for the pinout for the board? it is in the user manual.
01-06-2004, 05:04 PM
#11
Quote: Originally Posted by gospeed.racer
I guess I was looking for something like this .... found it ... tnx
1. CD - carrier detect
2. RXD - receive data
3. TXD - transmit data
4. DTR - data terminal ready
5. GND - system ground
6. DSR - data set ready
7. RTS - request to send
8. CTS - clear to send
9. RI - ring indicator
ALIBABA - I30 99
Nemiah M10000, C134
01-06-2004, 10:08 PM
#12
I could never get my second port working on my M9000 either. I don't think it's a power problem. I think the motherboard is flaky - the pins for the second connector didn't line up with the standard serial port plug.
01-07-2004, 12:28 AM
#13
The serial adapter on the M10000 uses the standard ASUS adapter. That's what I got, local computer shop guy gave it to me. That and a digital audio board from ASUS. Gonna try to hack that in during the rebuild. Digital audio (SPDIF and Optical) AND Composite video. May the force be with me.
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
01-07-2004, 03:59 AM
#14
good luck jackso.. i've practically given up on the onboard stuff on my m9000 hence my new vga and sound devices
| Thread Tools |
| Display Modes |
Linear Mode
