Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-14-2004, 03:38 PM   #1
craigyb's Avatar
USB audio box with optical and stereo
Just found this at the local Maplins store.....
Gives you L+R analogue mini jack output and Digital audio (TOS-LINK).
Not bad for £20.
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
craigyb is offline   Reply With Quote
Old 01-14-2004, 09:27 PM   #2
starfox's Avatar
Ah i have one of these in my car, bought it from Anyware computer accessories in Australia (they're a wholesaler).
Internally it has a USB to AC97 bridge, and a Via VT1612A Audio Codec IC in it (same as on the Via EPIA series motherboards). Audio quality is good! The only problem i have with it is that when windows or linux boots and initialises the device, the power to it drops off momentairily and it when it powers up again there's a rather loud thump that goes through the output jack. You could probably fix this by using some sort of speaker protector circuit.
They're good, i have a USB cable running from my car computer in the boot to this USB audio box which is right next to my amp.. hopefully this reduces the noise since USB's a balanced line ^^
http://www.via.com.tw/en/multimedia/vt1612a.jsp
If you want to look at the Audio Codec IC info
Only thing i wish is that the Line and Auxilary inputs were soldered in as well..
starfox is offline   Reply With Quote
Old 03-13-2008, 05:29 AM   #3
USB Audio Box
Hi there,
you wrote about some USB-to-AC97 converter chip. I am a hardware developer, and I am currently in need of exactly such a part. Can you tell me the part number or at least the manufacturer of the whole device?
Any information could be helpful.
Thank you very much in advance!
Best regards from germany,
Uwe
UweGuth is offline   Reply With Quote
