Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-15-2004, 01:00 PM   #1
wompser
Ribbon PCI riser cards w/ 2 slots???
Hello...
I don't know which riser to buy for my Epia motherboard. I know I need a card that goes from one PCI slot to two... but I also need one that is on a ribbon mount or cable mount because my case is so tight on space. (Basically I need it to fit parallel, on top of the motherboard. mini-itx.com sells circuit board ones, but they face the wrong way)
I've found a couple here:
http://www.mycableshop.com/2nd_Cat/R...RiserCards.htm
but I have no idea which is compatable. 32 bit? 64bit?? what does that mean?? 5 volt? 3.3 volt? I don't know what that means either! Any assistance is appriciated...
wompser is offline   Reply With Quote
Old 01-15-2004, 01:34 PM   #2
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
The EPIA is a 32 bit PCI slot and I thought that you need a speacial on for the 1 to 2 PCI slots?
Defiler is offline   Reply With Quote
Old 01-15-2004, 02:05 PM   #3
00CericaRuss's Avatar
00CericaRuss
http://www.buildyourserver.com/produ...er%20cards.htm
00CericaRuss is offline   Reply With Quote
Old 01-15-2004, 04:40 PM   #4
wompser
Hmmm... This still does not answer my question I'm afraid. I need a pci extender which goes from ONE pci slot to TWO. And it has to be flexible, so I can orient it a couple different ways. I think this is what I'm looking for: http://www.mycableshop.com/sku/RSRPCI2C.htm but I'm a bit scared by the picture. It looks like this does not have nearly enough wires/gold contacts to be the right thing I need.
I didn't see anything on the buildyourserver.com site, unless it would be easisest to use a PCIRX4-FLEX-A5 Right angle PCI 32 bit Flexible Extender in conjunction with a regular one to two pci adapter. http://www.mini-itx.com/store/default.asp?c=8#p50
Old 01-15-2004, 06:22 PM   #5
fantomas's Avatar
fantomas is on a distinguished road
that doesnt look like what you need... that just looks like it turns two pci slots into...two pci slots. not one into two..
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
which pci riser sive for m10000? [H]Bugster General Hardware Discussion 3 11-02-2004 05:16 PM
PCI riser cards Zensay General Hardware Discussion 16 10-19-2003 09:52 AM
PCI card riser card allenruble Classified Archive 1 11-25-2001 08:51 AM
New powersupply! Question about PCI riser card. jssaggie Power Supplies 2 08-30-2001 09:34 AM
adding pci slots? etrik General Hardware Discussion 2 04-04-2001 08:28 PM
