Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-01-2004, 01:06 AM   #1
[H]Bugster
help, my head unit doesnt work anymore
I have a 2002 Ford Ranger XLT with a stock head unit. While installing my computer and running power lines....i was tapping into the head unit's ignition wire (switch power) for my ITPS (psu is pw70a). Then i tested the computer, but it ddint power on. After poking around with a multimeter, i realized that the iginition wire wasnt providing 12V.
I put the headunit in to see if it is getting power...and it does not work now. The only thing that it does when i plug it in is eject the cd, show the time and then it turns off completely. What did i do that the plug???!?!?!?! How do i fix it??!?! Im so frustated, been working all day to get the wiring in, and now this happens!
[H]Bugster is offline   Reply With Quote
Old 02-01-2004, 01:17 AM   #2
jusatry's Avatar
jusatry is on a distinguished road
check your fuse maybe?
jusatry is offline   Reply With Quote
Old 02-01-2004, 03:50 AM   #3
Jackso is on a distinguished road
if it was a stock head unit, it is possible that there was some form of theftlock (GM uses Delco TheftLoc). Once the power it removed from the headunit with it locked, the headunit will no longer work. If that is the case, you're fukt. There is no fixing it supposidly.
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
Jackso is offline   Reply With Quote
Old 02-01-2004, 03:53 AM   #4
Nic
Nic's Avatar
Nic is on a distinguished road
isnt there normally a way around it, like a code you can put in, what u supposed to do if your battery goes flat???
Nic is offline   Reply With Quote
Old 02-01-2004, 04:13 AM   #5
[H]Bugster
but if thats the case....there would still be power going through the switched power wire right? Theres no power going through that wire at all
Can a car-computer replace a stereo head unit? CA 3000GT General Hardware Discussion 22 11-13-2006 10:24 PM
Alternate locations for head unit? Raekwon General MP3Car Discussion 13 04-09-2003 04:02 PM
Anyone using a Clarion DX515/db head unit or know if it will work for my carputer? wysiwyg General Hardware Discussion 0 01-06-2003 02:35 AM
Slot load dvd in a head unit mp3truckstereo General Hardware Discussion 1 09-01-2002 11:17 PM
car head unit BoneMan General Hardware Discussion 1 07-29-1999 10:30 PM
