Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-07-2004, 10:03 PM   #1
LESLIEx317537's Avatar
Thumbs up EPIA VIA M10000 Mini ITX in a 6x9 Speaker Box pic. 2 hour build time.
I made this for my friends Jetta CarPC.
Got two boxes for 20 buks and cut one up.
The char LCD still needs to be mounted.
That's a 120GB 8MB buffer 7200rpm drive in the corner.
A night dark shot will look alot better. Soon to come.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Advertisement Sponsored links
Old 02-07-2004, 10:19 PM   #2
Raw Wave
wizardPC's Avatar
SWEET!
I need a new enclosure.....
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 02-07-2004, 10:23 PM   #3
Thanks wizardPC.
Your a old school member huh.
My 3rd box in my STi is a 10" Sub Box. Built in a similiar fashion.
I like the boxes and then some plexi on top. Looks great when the LEDs and lights go on.
Old 02-08-2004, 03:26 PM   #4
ANother snap.
Old 02-09-2004, 04:18 PM   #5
What and/or where did you get that speaker box? This may be perfect for what I want to do.
Nanozic is offline   Reply With Quote
Old 02-09-2004, 04:33 PM   #6
PHiLiSO's Avatar
I second that. Is there any possible way you could write up a quick tutorial for this, nothing too indepth but just let us know what you used I would definately do something like this.
PHiLiSO is offline   Reply With Quote
Old 02-09-2004, 04:43 PM   #7
Sure, I'll try to think up of steps to make it simple as possible.
I'll look for links to boxes and the tools I used. Shouldn't be so hard. I'll post later.
Old 02-09-2004, 05:13 PM   #8
PHiLiSO's Avatar
cool im ordering my parts tonight for mine, gonna try to do the same thing you did here.
Nice job on the dash install too, what type of bondo did you use?
Old 02-09-2004, 10:33 PM   #9
Awesome job! I'm definetly gonna try this for my setup Looking forward your post with some directions.
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
[iG] is offline   Reply With Quote
Old 02-09-2004, 11:11 PM   #10
OK, you need a couple of items besides the Motherboard/PS/ITPS + HD.
Speaker Boxes: http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3292 $9 dollars for two + shipping cost.
Plexi glass: 11x14 inch sheet, score with knife and snap in half $2 dollars.
Cool LED fan: Any brand $5-10 dollars.
Tools Needed:
Skil saw and drill.
First the plexi needs only 1 large hole for the fan. I used a 8cm holesaw in reverse to cut the hole. Made 4 small holes so the fan could be screwed into the plexi.
Then made 4 holes in the corners for screwing into the box. Use the drill in reverse!
Next comes the box.
Using a Skil saw or similar.
Cut the top rectangular to the size you want. You can place tape along the box as a guide. Then cut the back bottom half open in the back.
Screw in the motherboard, Velcro in the HD sideways, and screw in the ITPS etc.. Wire it up to a lit switch like mine if youw ant to signal the ITPS is putting out voltage or to keep the PC from booting.
And screw in the fan and then pop the top on, and your done. Put it in the corner of your trunk with some Velcro on the bottom.
I hope that helps.
Old 02-10-2004, 10:53 PM   #11
PHiLiSO's Avatar
very well thanks. one question. did you bolt everything right to the wood or some other way?
Old 02-10-2004, 10:59 PM   #12
The HD is velcro'd in, and the ITPS and Motherboard are screwed into the wood.
Old 02-11-2004, 05:26 PM   #13
what are you planning on displaying on the LCD?
btw, is that a STI?
Old 02-11-2004, 06:06 PM   #14
Thats a damn good idea!!! Nice!! I wish I would have thought about that.
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 02-11-2004, 06:47 PM   #15
It's my friend box I built for him so he can decide what to display in his USB Crystal Fontz Char LCD. Probably just uptime and temp.
Yes, I got my STi in August 2003. Lovn it.
