The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-01-2004, 05:40 AM   #1
craigyb's Avatar
Vehicle: 2001/Toyota/Hiace
My Photos: (0)
Me experiences with the D-link USB radio
OK, this weekend I took the plunge and wired in the D-link USB radio to use with Confused's radio skin and radiator within MediaCar.
I had the PC out of the car and on the bench, installed radiator, as I had Garry's latest skins, everything else worked fine. I saved several stations tested MediaCar functionality, all seemed fine.
Next I cut into my aerial lead just behind the HU and plit it in two, sent one to the HU and one up to the glove compartment for the D-Link. HU functioned fine, tested for signal, tuning etc all ok.
Installed the D-link into a 4 port HUB behind the glove compartment, attached the aerial lead (phono connector fitted) and sent the audio down a screened cable back to to the PC in the boot.
Hmm, how dissapointed was I, very poor reception and engine whine.
Now me thinks that the engine whine could be fixed by building the D-link into a metal project box and I have such a thing ready for next week, but what about the poor reception, has everyone else had this problem?
I seem to remember several threads regarding the radio reception quality.
Craig
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
craigyb is offline   Reply With Quote
Sponsored Links
Old 03-01-2004, 05:45 AM   #2
Raw Wave
Confused's Avatar
Vehicle: Honda Prelude 2.2 VTEC / Ford Anglia 105E
My Photos: (0)
I have yet to try this...but I quite probably will be next weekend.
One thing I seem to remember from reading here, is that the ground is actually on the inside of the phone connector, and the signal on the outside.
I'm glad all the functions worked...just apart from the reception
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 03-01-2004, 05:50 AM   #3
craigyb's Avatar
My Photos: (0)
Bugger, I seem to think your right. That all makes sense now. Anyhow, I will build it into the metal box and add a filter or two, I will be removing the phono socket, so I will be able to see what is ground and what is signal, thanks Garry.
Still got my shutdown controller to install, ran out of time this weekend.
Craig
Audi S8 supercar
Toyota Hiace Van
Old 03-01-2004, 09:46 AM   #4
My Photos: (0)
Spliting the signal will cost you some reception quality
lummox is offline   Reply With Quote
Old 03-02-2004, 11:23 PM   #5
LESLIEx317537's Avatar
Vehicle: STi
My Photos: (0)
I did the same exact thing.
I should have taken pictures, mine has the standard car antenna male and female connections.
I did alot of testing on it. I took and grounded the outer conductor to the line out's outer conductor and it got rid of alot of the whine.
Next, I unplugged my headunit antenna and some more noise went away.
If you mute the line in the noise will go away. - I wonder if there is some program that mutes and unmutes the line in when the radio is in use and not.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 03-02-2004, 11:37 PM   #6
FLA
gospeed.racer's Avatar
My Photos: (0)
I cut mine apart and the center pin is what is soldered to the base of the antenna. It is odd that there are people using it both ways and both seem to work
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 03-02-2004, 11:41 PM   #7
Vehicle: STi
My Photos: (0)
I tested mine and made sure which was the signal and ground.
Old 03-03-2004, 02:18 AM   #8
00CericaRuss's Avatar
Vehicle: 2000 Toyota Celica GT-S
My Photos: (0)
i've found that i get a bit better reception w/the outer pin of the rca going to the ground of the antenna
Car: 2000 Toyota Celica GT-S
Mods: Yep
Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
00CericaRuss is offline   Reply With Quote
Old 03-03-2004, 02:20 AM   #9
Vehicle: STi
My Photos: (0)
Exactly what I did. Got rid of some whine I had.
Old 03-03-2004, 09:13 PM   #10
Vehicle: STi
My Photos: (0)
OK, I need to know what everyone hooked up the center antenna conductor to and what they grounded the outer sheilding of the antenna wire.
I hooked what is circled in blue up to the center pin/wire on my cars antenna wire.
I also think I know why the whine is coming in... I'm going to see if I can make this thing work really nice now that I'm gonna go headunitless.
Sponsored Links
Old 03-06-2004, 06:35 PM   #11
Vehicle: STi
My Photos: (0)
I did some more testing and found that the 1/8th line out shielding is not grounded at all.
I'm gonna bypass running the 1/8th audio line with the USB cable and make a hole in the unit and snake the wire out directly and ground the outer shielding.
Here's the exposed shielding that goes nowhere. (I think)
Old 03-14-2004, 01:45 AM   #12
My Photos: (0)
just tacking on here for future reference.
2002 Subaru WRX - Silver
-FP18G turbo
-Walbro fuel pump
-Modified OEM 840 CC Injectors
-TurboXS: UTEC, turboback, uppipe, intake
-Blitz FMIC
-STI cluster
-17"x7.5" SSR Competitions
-Tein Flex coilovers
-NOS 50 shot
-2004 rear conversion
imprezive one is offline   Reply With Quote
Old 03-14-2004, 05:12 PM   #13
Vehicle: STi
My Photos: (0)
Another note.
I was reading this very helpful thread: http://forum.sounddomain.com/forum/u...c;f=5;t=008251
I now also think that powering the car antenna amp with the accessory on may also possibly cause noise? How many amps do you think it draws? I was possibly thinking of powering it with the PC power supply.
Another thing I might do is ground the dlink unit to the grounding distro block.
Old 03-16-2004, 03:27 AM   #14
Vehicle: 1996 Honda Accord EXV6
My Photos: (0)
d-link is crapola!
Guys, guys, guys, don't you search old threads??? I posted numerous times how bad the d-link reception is. Many people have tried putting metal boxes, soldering this, doing that, but why not go ahead and buy the hauphauge????
Whats so special about the d-link? The wintv is about the same price too!! I have both and I can tell you that the d-links reception sucks ***! Hauphauge is the way to go, Just my opinion from someone who has both.
http://www.bankingdom.com/carputer/carputer.html
bankingdom is offline   Reply With Quote
Old 03-16-2004, 04:15 AM   #15
Registered User
Mastero's Avatar
My Photos: (0)
OK friends today i worked on my D-link result was no engine whine, amazing reception as good as a headunit.
Shall post full details from home at work right now.
Mastero
mastero76@hotmail.com
NEW LINK TO MY SITE ]{*}CYBER SHOP ONLINE{*}
AIRCON UNIT VER 2 IS NOW FOR SALE ]
Life is short enjoy it before it ends.
Mastero is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
My experiences with various components... Defiler General Hardware Discussion 0 01-27-2004 01:49 PM
USB Radio orangewhip General Hardware Discussion 1 03-13-2003 05:37 AM
WTB: D-Link USB FM radio Stine161 Classified Archive 4 11-12-2002 07:02 AM
Dlink USB Radio Screenshots veedubya General Hardware Discussion 7 10-20-2002 08:38 AM
usb radio shawn General Hardware Discussion 15 07-01-2002 07:04 PM
Sponsored Links
Ad Management by RedTyger
