Z919 Pinout
mattJw,
I'm going to use the pinout you have and try to get this to work!...
Judging by what I see in the image, it looks like there are two pins, bus+ and bus-, which are directly supplying power (I assume that is ~12V power, limited to 0.9A according to an old spec I found elsewhere online). DO NOT short those together!! (smoke will likely be the result, along with a dead radio.)
Next, I notice a bus on and bus off... each has a 1K resistor pulled up to bus+.... I suspect that shorting bus on to GND or bus- (I'll try bus- first) will tell the radio that something is on the bus. Since there is a bus off signal, I'm assuming bus on may only need to be "pulsed" to kick the thing on.
I will probably try this through a secondary 1K resistor first, to reduce the likelihood of anything going wrong (12V across 1000 ohms will draw approximately 0.012 Amps of current, well below the 0.9 Amp max for the bus+, bus - power supply output).
Anyhow, once I get the radio to recognize an auxiliary input is present, I will try connecting an audio input to the AUD L, AUD R, and AUD G inputs (L +, G -) and (R +, G -). As you may note, the left and right inputs will share the AUD G pin as the "-" input for each.... -The diagram shows a capacitor inline with those inputs, so these must be a very high impedance circuit with a capacitor inline for DC isolation. That's a good thing, as you need high impedance inputs for something like an ipod or other MP3 device.
The other audio inputs, four of them plus a common ground for those.... They look like they may be a 4-channel speaker level input much like what would be used to connect the Z919 to a 4 channel decoder or even another car stereo. I have no need to try using that feature, so I'm not personally going to play with that unless someone can determine what the maximum and minimum input power levels are for those inputs.
Once I get this all working on a test bench, I'll try to connect a set of RCA cables to the appropriate connector pins using jumper wires or something along those lines.... I have to do something because I really want to use my ipod with my car stereo!...
Anyhow, thanks for the diagram.
