03-04-2004, 07:58 PM
#16
BTW, I learned how to solder in 8th grade when a friend of mine who's father worked for Grumman. He was always making stuff. He one day was like you wanna try to make a FM transmitter? And I was like sure.
We went out to radio shack bought resistors, a electric mic, and some other stuff like variable resitors and I couldnt find a coil so I made my own.
Anywayz, the best tip is to heat up both ends to be soldered first then touch then together and apply the heat. Use as little solder as possible. I've been doing that technique since 8th grade and it works great. I think it's called tinning?
03-04-2004, 08:09 PM
#17
How do you heat up both ends to be soldered with one iron? You mean heat oen up then let it cool down while you are heating the other one?
Thaks for the info, that projet looks tight.
03-04-2004, 09:32 PM
#18
No, you heat up both sides and coat it with solder.
Then touch both coated things together and apply heat and it will fuse them both together.
03-04-2004, 09:46 PM
#19
That's incredibly a good idea! That makes things SO much easier! I need to find someone in my area that can do that for me (I have shakey hands). I'm kickin' myself in the *** for not thinking of that! Thanx!
Just your friendly neighborhood computer specialist.
2002 Pontiac Trans Am WS.6
Silver/Black
Looks like new... Wanna know why they call me "Crash"?
03-06-2004, 03:21 PM
#20
i dont think its called tinning.... but whatever its called..its probably the easiest way to do it (melt solder onto both parts.... then push them together while applying heat)
i believe tinning is when u melt a small amount of solder onto the tip of the soldering iron.... if u dont do this , heat wont transfer as well
AT mobo
Intel Pentium MMX 233mhz
ESS Solo PCI soundcard
Linksys NIC
Irman
03-09-2004, 09:55 PM
#21
no, you were right the first time. tinning is when you put solder on the objects that will be soldered and you apply heat
03-09-2004, 10:07 PM
#22
cool, thnxs for verifying that.
03-09-2004, 10:39 PM
#23
The way leslie did it is the best. YOu apply heat to the wire and then touch the solder to the wire and if done right the solder looks like it gets sucked into the wire but really it just coats it.
So all you did was open both the faceplate and the HU and wired them together? Did you have to use the cat5 cable or could you have just used single wires? I am guessing you can use both, just the two cat5 cables are easier to work with, right? Do you know how it is working now that you did that?
03-09-2004, 10:49 PM
#24
Still working, I used stress relief.
Yeah the cat 5 cable is good cause you can add connectors and then you run the cable to where you want, then connect it.
03-22-2004, 12:23 AM
#25
Just a few questions. How long was the cat 5 cable? Also did this affect the brightness of the display?
05-18-2004, 01:50 PM
#26
It's not really that small...No, seriously.
Just because I am still nervous to do this, I will bring it back from the dead....
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
05-18-2004, 02:01 PM
#27
Nothing was affected.
Also, my friends CarPC still is working.
05-18-2004, 08:09 PM
#28
A friend of mine was wanting me to do that to the display of his home stereo in his theater... he has a front projector and then his components are installed in another room but he'd like to have the stereo display visible from his main seating in the theater. I was thinking the CAT5 cable would be the way to go as well... modular (RJ-45) ends and then he can have a jack to plug into. This is inspirational... I think I'm gonna give him a call this weekend... maybe get this done ASAP... if I do it, I'll take some pictures... GREAT job!
Coach... aka Randy!
05-24-2004, 11:03 AM
#29
Well I did it this weekend. It works. I didn't solder on the board, but rather to the exisiting connections on the HU and face plate. I need to find a place to mount it now in my car. I wish the cat5 was a little more flexible, I feel as though I'll break off the solder connections if i play with it too much while trying to mount it.
I'll have pictures in the future.. no internet at my new house just yet... :0
'02 GTI
05-24-2004, 11:24 AM
#30
Banned
This should be a sticky. People need to see this idea BEFORE they plan out their carputer. I'm just glad someone brought it back up.
| Thread Tools |
| Display Modes |
Linear Mode
