The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 07-08-2004, 08:52 AM   #46
Marsupial's Avatar
My Photos: (0)
judoGTI, you should place it in the sunvisor, it would be 1337!
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
Sponsored Links
Old 07-08-2004, 09:19 AM   #47
It's not really that small...No, seriously.
judoGTI's Avatar
Vehicle: '02 GTI
My Photos: (0)
I thought about that but I didnt want to flip it down to see it while driving. And I wanted to make sure my remote had a clear line of sight to it because it gets finicky if it doesnt have one.
I also thought about above my rear view mirror, but it was about 1/8" to big to fit.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 10-16-2004, 01:36 PM   #48
modUlarBeing's Avatar
My Photos: (0)
A place someone told me i should do mine is the rear view mirror....just bust out the glass and mount it inside....but no mirror.....
just a thought
modUlarBeing is offline   Reply With Quote
Old 10-16-2004, 02:26 PM   #49
LESLIEx317537's Avatar
Vehicle: STi
My Photos: (0)
That is not a good idea.
Legal issues, plus you won't see me speeding by you and you might cut me off, unless you got a rearview camera and screen.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 10-16-2004, 07:09 PM   #50
My Photos: (0)
yah i told my friend that im sure its illegal plus since i want it i would just as well mount it under my mirror
Sponsored Links
Old 10-26-2004, 07:43 PM   #51
My Photos: (0)
i just tried doing a remote faceplate on my car and its not working, i have soldered it 3 seperate times thinking it might have been a bad connection but its not. has anyone figured out what kind of limit there may be on the length? i think my cable might be 6 or 7 feet long.....i basically am leaving the radio sit behind the lcd and running the face up to the headliner.
Old 10-26-2004, 08:02 PM   #52
Sporttracguy's Avatar
Vehicle: 2001/ Ford/ Explorer Sport trac
My Photos: (0)
i did this and it worked fine with that length(mine is longer) be sure to check on the head unit to see where the faceplate connected there. sometimes there is a switch that needs to be pushed down to make the head unit think there is a faceplate there.
Sporttracguy is offline   Reply With Quote
Old 10-26-2004, 08:20 PM   #53
My Photos: (0)
yah i pressed the button down. , i have two cat5 couplers hooked to it which im not sure if they could be causing loss in something......i have a pioneer HU. i have done this solder job 2 times and my friend tried once and we cant get it to work argh!
Old 10-26-2004, 08:32 PM   #54
judoGTI's Avatar
Vehicle: '02 GTI
My Photos: (0)
I would just trace the wires, it sounds like you have one backwards or you have solder touching between terminals. Mine is longer than 7 ft and works OK. I did have problems with the screen shorting when I had solder touching, but once I cleaned that up it works like a charm.
'02 GTI
Old 10-27-2004, 01:24 AM   #55
Vehicle: STi
My Photos: (0)
Which head unit do you have?
Keep trying, make sure nothing is shorted, test the connections with a multimeter. Put it on audible beep mode.
Old 10-27-2004, 07:29 AM   #56
My Photos: (0)
I have the Pioneer DEH-7600MP
http://www.pioneerelectronics.com/pn...891888,00.html
Old 10-31-2004, 09:25 PM   #57
My Photos: (0)
well i finally got mine working.....
turns out that the cat5 coupler was KILLING the coltage, there was more than a 90% drop through that coupler!. so now its soldered straight to the HU. I dont plan on using the cd player so its not a big loss. I will post pictures later.
Old 11-01-2004, 09:25 AM   #58
Vehicle: STi
My Photos: (0)
The coupler gauge must be thin.
Glad you got it working..
Old 11-01-2004, 09:59 AM   #59
brrman's Avatar
Vehicle: 2000 Audi A4 Avant 1.8t quattro
My Photos: (0)
Quote: Originally Posted by judoGTI
I wish the cat5 was a little more flexible, I feel as though I'll break off the solder connections if i play with it too much while trying to mount it.
What you have to do now is take a standard glue gun and melt glue onto the board where the solder points are. This will keep the soldered wires safely in place. I do that all the time.
Car: 2000 Audi A4 Avant 1.8t
Carputer 2.0: M10000, 512 ddr2100, Xenarc 7", Opus 150W
Audio: Hifonics ZX6400, Hifonics ZX4000, Infinity Kappa Perfect 5.1 front, Hifonics Zeus ZS62CX 6.6" rear, Infinity Perfect 10.1 Sub
Complete: [0%-------X-100%]
brrman is offline   Reply With Quote
Old 11-01-2004, 10:03 AM   #60
My Photos: (0)
So much for me asking how you'd eject a CD.
jeepguy is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
