Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-17-2005, 10:48 PM   #76
Hark's Avatar
Hark is on a distinguished road
Any more recent updates to all these efforts???
Hark is offline   Reply With Quote
Old 10-18-2005, 08:24 AM   #77
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
if the volume is controllled by a variable resistor pot in the face theres a chance the long wire run is adding to the resistance enough to affect the volume control....IF this is the case the only solution would be using wire with less resistance on that circuit(if you caneven isolate it) or shorter extention??
turbocad6 is offline   Reply With Quote
Old 10-31-2005, 11:41 AM   #78
munkynpunky's Avatar
munkynpunky is on a distinguished road
Hey, I love this idea and I'm gonna deffinately have a go at this, I have a Pioneer P6400R head unit, and I have a spare back since the plastic surround has been ripped off it.. So i have a head unit to test with before i shag my actual stereo..
Car is Dead, Hand is burnt - Let that be a lesson to me! never open the bonnet when you smell burning.
http://www.digital-car.co.uk
munkynpunky is offline   Reply With Quote
Old 11-01-2005, 11:29 PM   #79
Hark's Avatar
Ugh, having the worst luck trying this with an Alpine CDA-9855. I must've soldered it 5 times now, and all I get is working buttons, some lights, but no screen. Using Cat-5 like others, and using a volt meter to ensure everything's connected ok, no crossed cables, double-checked wires... so frustrated.
Old 11-01-2005, 11:31 PM   #80
Hark's Avatar
Quote: Originally Posted by modUlarBeing
well i finally got mine working.....
turns out that the cat5 coupler was KILLING the coltage, there was more than a 90% drop through that coupler!. so now its soldered straight to the HU. I dont plan on using the cd player so its not a big loss. I will post pictures later.
I'm a little new with the electronics stuff... I'm using a volt meter to measure resistance between the contacts over the wire to ensure each contact is connected. Is this what you're talking about, or are you actually measuring voltage? I'm also using cat-5 couplers, but since the resistance measures the same with them on/off, I didn't think they were affecting anything.
Old 01-22-2006, 05:50 PM   #81
DaveB's Avatar
DaveB is on a distinguished road
Hark,
Did you get yours working? All my buttons work, the CD plays, but no LCD screen. I'm interested in how you fixed yours?
DaveB is offline   Reply With Quote
Old 01-22-2006, 09:32 PM   #82
Hark's Avatar
LOL - I gave that up a while ago. Had the same problem, no LCD screen. I even had a local radio shop that claimed to be able to do it before give it a try, with no luck (on my Alpine CDA-9855). I think these new screens need too much juice and the long connection can't do it.
I bought an XM radio (XM Direct) instead, and am so glad I did. SOOOOO much better.
Old 01-25-2006, 10:53 PM   #83
DaveB's Avatar
Bad news. None of the newer CD receivers are capable of having the faceplate relocated. They have gone to a design where its really tough to solder the wires in place.
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
Old 01-25-2006, 11:48 PM   #84
Raw Wave
justintime's Avatar
justintime is on a distinguished road
I am going to try to do this with my HU. What's so particular about mine, is that the volume, bass, and treble knobs are physical pots. So my plan is to wire all the pins on the board, and then also wire the pots end to end. Not sure if this will work though, but I have 2 units, so if I screw one, who cares.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 01-26-2006, 03:18 AM   #85
DaveB's Avatar
The HUs with the motorized faceplates use a tiny ribbon cable from the HU to a socket that sits on the movable backing plate, which the faceplate attaches to. There is virtually nothing you can solder to on these. The sockets are soldered to one side of the board. There are no solder pads on the back side of the board. If you try to solder to the front side of the board, the thickness of your wires will hold the circuit board away from the case.
THe only way you could solder your wires is by soldering to the pins on the face-off connector. If you do that, you wreck it and you can't go back to stock. So if you go through the work of soldering it all up and you find the LCD doesn't work, you've wrecked your HU.
I've bought and taken apart brand new Sony, Pioneer, Panasonic and Kenwood CD receivers in the last 3 days. None of these new receivers are very promising for remoting the faceplates. They have moved to a construction method which pretty much precludes soldering wire leads onto the connections. The new faceplates use microcontrollers that put out such little power that the distance of the cables will likely result in a non-functioning LCD.
I considered making a mold of the male/female sides of the IC thinking that this way a guy could make an extension cable without soldering anything to the HU or faceplate. But I couldn't figure out how to embed the metal pins into the molded pieces.
I also tried to locate the male/femal sides of the IC at electronics suppliers but didn't have any luck. It would help if I knew the technical names for these pieces.
Bottom line....you need to buy a reciever that is at least a year old because the new stuff is really tough to work on.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Old 01-26-2006, 07:27 AM   #86
It's not really that small...No, seriously.
judoGTI's Avatar
judoGTI is on a distinguished road
Ebay Ebay Ebay for those older receivers! lol
Anyony tried beefier cable? Cat 7 maybe?
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 01-26-2006, 10:34 AM   #87
DaveB's Avatar
Yep, I am buying off of ebay. I'll be using a 10 foot DB25 computer cable.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Old 01-26-2006, 11:47 AM   #88
Vita is on a distinguished road
anyone sucessfully do this with a stock GM Delco head unit?
Vita is offline   Reply With Quote
Old 01-27-2006, 08:28 PM   #89
Raw Wave
justintime's Avatar
DaveB: Did you try a HU with DETACHABLE faceplate, instead of the motorized/tilting ones? Those are more likely to have standard pins etc, without flimsy ribbons....
I think Alpine's are being used a lot for remote face plating...
2002 Honda CR-V
Old 01-27-2006, 09:45 PM   #90
Hark's Avatar
*cough* post 33 *cough*
