will that fit in the M10000 and full size HDD and DVD-ROM? im trying to find a case that will fit the m10000, full size drives, full size ram and still be in the BOOK style case. thanks
The 2699 will fit a full size (3.5") HDD and most of the taller RAM sticks, but not a full size DVD-ROM. There's only enough room in that case for a slim optical drive.
- Sony XAV-7W In-Dash 7" LCD
- Via EPIA 800MHz
- 256MB SDRAM
- 40GB HDD
- Targus Wireless Remote
- Win 98SE See it Here or Here (cardomain.com)
It will fit a full size hdd but requires a slim dvd drive. Full size RAM will fit but may be tight depending on your cables. You can also fit a full size PCI card using the 90 deg riser. It's a nice little case. I have a M9000 in mine but it's the same size as the M10000.
Have you considered a cube case like this?
Not quite a book PC but still pretty small.
- Via EPIA 800MHz
- 256MB SDRAM
- 40GB HDD
