The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-17-2004, 04:41 AM   #1
My Photos: (0)
Auto reverse camera
I'm going to be using (as soon as i get my Opus) a 7" Lilliput touchscreen with a weatherproof camera for reversing. I know the lilliput has a plug directly for the use of a camera. My question is this... how can i get to view the reverse camera as soon as i put the car in reverse??
Is there no other option other than pressing a button on the screen to switch modes?
Tha Hombre is offline   Reply With Quote
Sponsored Links
Old 03-17-2004, 05:11 AM   #2
eCar™'s Avatar
Vehicle: '03 Ford Taurus SES
My Photos: (0)
Don't know exactly how the Lilli switches to A/V input, but I just worked out the same thing using a Cheese Box. I used that because my LCD controller is VGA in only. The Cheese Box converts the A/V signal to VGA.
It was very simple because the button that switches from VGA to A/V input is the latching type. Meaning that when you press the button, it latches two contacts together, and displays the A/V input on the monitor. When you press the button again, it unlatches the contacts, and VGA signal is passed thru.
I took the switch off the Cheese Box. I connected two wires to where the switch used to be, and ran them to a relay. The relay is triggered by the reverse lights on the car, so when you are in reverse, the contacts are made at the Cheese Box.
I added a 3 position switch to allow for; A) Relay gets trigger from reverse lights; B) Relay gets trigger from constant 12V (so I can turn camera on without being in reverse); and C) No signal to relay (so I can be in reverse without the camera being on).
I suspect the Lilli changes from one input to the other by pressing and releasing a button. Then you'd have to press and release again to get back to the other input. Is this the way it works?
eCar™ is offline   Reply With Quote
Old 03-17-2004, 06:40 AM   #3
doig's Avatar
Vehicle: 1989 BMW 318i
My Photos: (0)
What camera did you end up using out of interest?
doig is offline   Reply With Quote
Old 03-17-2004, 06:59 AM   #4
eCar™'s Avatar
My Photos: (0)
I actually don't have a cam yet. But something like this is probably what I'll use. It will fit in the lens for my third brakelight. Just need to drill a hole in the red brake lens, and glue in a clear piece.
Old 03-17-2004, 08:09 AM   #5
My Photos: (0)
I would probably not recommend buying the cameras from DigitalWW until you find a decent way to enclose them. The plastic domes are not sturdy and break very easily. Its just my opinion, the cameras are great other then that.
I bought this one. Its already in a solid water proof, metal enclosure.
EDIT: It looks like your already taking care of the enclosure part, but in case you weren't.
King_Aero is offline   Reply With Quote
Old 03-17-2004, 08:14 AM   #6
eCar™'s Avatar
My Photos: (0)
It will be inside my brake light. As protected as the bulbs in there. Should be fine.
Old 03-17-2004, 08:37 AM   #7
Custommx3's CarPC Specs
Custommx3's Avatar
Vehicle: 2007 Mazdaspeed6
My Photos: (7)
I bought the same camera, hopefully it will be a good one. I was debating on the IR cams, but went ahead w/ this one.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 03-17-2004, 09:25 PM   #8
Vehicle: 95 Toyota 4Runner
My Photos: (0)
Hey Ecar I have the infrared version of that camera though I did not buy it from digitalww. I am having a problems because when I connect it to my monitors I do not get any video on the lilliput 7' TS but I do get an image on my Jensen monitors in the headrest. I am stuck right now thinking of how to get this to work
95 Toyota 4Runner
Elliott's MP3 Runner
Components of my setup takes up way more than 250 characters and no matter how I tried to make it fit here it just wouldn't so please check my page.
Dluvr22 is offline   Reply With Quote
Old 03-17-2004, 10:36 PM   #9
eCar™'s Avatar
My Photos: (0)
Are you connecting the camera directly to the Lilli?
Can you connect something else to the Lilli to see that it's working?
Old 03-17-2004, 11:04 PM   #10
Sway's Avatar
My Photos: (0)
just a suggestion but you might want to look into a $20 2.5 LCD Screen Controllers for XBox and use that as a rear view screen as someone suggested in another thread
http://www.compusa.com/products/prod...647&pfp=BROWSE
Sway is offline   Reply With Quote
Sponsored Links
Old 03-18-2004, 06:42 AM   #11
Registered User
aoLhaTer's Avatar
Vehicle: 04 Infiniti G35 Coupe
My Photos: (0)
id support this idea
id love to have an automatic switching method but it would be complicated
theoretically, you could connect some sort of mechanism to the reverse light (either on dash or tap into the line from the rear lights) and then the mechanims goes "oo theres 'so and so' voltage running over this line, time to switch to x input" then when the wires state returns to normal the video switches back
this is way out of my league though so id just do a seperate lcd
unfortunately i missed out on this deal
aoLhaTer is offline   Reply With Quote
Old 03-18-2004, 08:02 AM   #12
My Photos: (0)
Yes for troubleshoting purposes I connected it directly to the lilliput on Video 2. My computer is on the vga mode and dvd plaver uses video 1. Even when I connect the camera to video 1, I get " no video input" on the screen but when I put the dvd back, It plays. This is frustrating .
95 Toyota 4Runner
Old 01-09-2005, 12:17 AM   #13
ramy_zohair's CarPC Specs
ramy_zohair's Avatar
Vehicle: 2002 Mitsubishi Magna
My Photos: (0)
Arrow Diagrams & Sticky
Hey eCar. lovely way of connecting a backup camera. It would be much better if u could draw the whole connections diagram.
This must be a sticky then.
Keep up the good work
ramy_zohair is offline   Reply With Quote
Old 01-19-2005, 11:29 PM   #14
Sofa King Retarded
nsmoller's Avatar
Vehicle: 2004 Toyota 4Runna
My Photos: (0)
where does teh switch go
i agree diagrams a must!
[4Runna]
next - wifi
nsmoller is offline   Reply With Quote
Old 01-19-2005, 11:36 PM   #15
Registered User
aoLhaTer's Avatar
My Photos: (0)
See this thread
http://www.mp3car.com/vbulletin/showthread.php?t=26031
Sponsored Links
vB code is On
Trackbacks are Off
camera question.... Tripp General Hardware Discussion 3 04-16-2005 12:49 PM
Best DVD / camera software? Tha Hombre Software & Software Development 0 02-06-2004 09:03 PM
Software for rearview/backup camera? nxt125 Software & Software Development 2 07-21-2003 06:34 PM
Reversing camera hapination LCD/Display 0 05-20-2003 02:48 AM
Have video camera for rear view - which program? nxt125 Software & Software Development 0 08-14-2002 11:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
