Quote: Originally Posted by anaxagoras
I searched, but really could'nt find any clear cut answers.
I have a 2001 mustang with a Mach 460 sound system. I intend on repalcing my head unit with my sound card, but for the time being i want to stick with the stock amps and speakers cuz i can't afford much else right now.
So i'd just end up using RCAs for inputs to my wiring harness somehow?. How would I go about doing this?
cut 'n solder
get a wiring harness for your 'stang, (local stereo shop or online), cut your RCAs (or radio shack has a little board that has RCA in on one side and spkr terminals that are soder friendly on the other), figure out which wires are FR, FL, RR, RL and grounds, find a switched 12V to turn the system on (i suggest putting a toggle switch on this as an audio kill switch....just in case), get a sound card that can handle the number of channels you need (usually 4 for the stock amp in the car, 5 or six if you have an aftermarket sub or want a center channel). Run the RCAs from the sound card into the wiring harness, then snap on when ready. Switched 12V and presto.
Your system may have "balanced inputs".....but my audi bose system works fine with the system i just outlined - i am using an m-audio theater USB external sound card for 4 channels, its working fine.
post if i wasnt clear or you have questions.
