The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Search this Thread Display Modes
Old 04-07-2004, 09:29 AM   #1
My Photos: (0)
Possible Vibration solution...
this is just something that sorta occured to me...but what about booting to a USB hard drive and keeping that up front where it's got less shock? You could get one ofthe USB 2 enlosures for a laptop HD and boot from that...usb2 is plenty fast enough..any thoughts? This is just something that is crossing through my mind and I figured I'd get some input..
codelogic is offline   Reply With Quote
Sponsored Links
Old 04-07-2004, 10:58 AM   #2
Raw Wave
wizardPC's Avatar
Vehicle: $800 1995 Plymouth Neon
My Photos: (0)
Shock isnt nearly as big a problem as most people think. Theoretically, one would think that the vibrations of a car driving around would ruin a hard drive quickly. In practice, however, hard drive failures due to shock are rarely seen. Note that I said rarely and not never.
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 04-07-2004, 11:06 AM   #3
My Photos: (0)
I plan on placing a mini-itx computer in my glovebox, it will also be used as a second computer so it will have to be removable. If i supported it between two layers of sponge would it be enough to remove any large impacts from hitting potholes and also reduce the vibrations?
Thanks for any help,
The Kevster
The-Kevster is offline   Reply With Quote
Old 04-07-2004, 04:08 PM   #4
pip
pip's Avatar
Vehicle: 2000 Suburban & 2002 Corvette
My Photos: (0)
I am no expert, but I suspect the sponge would act as a damper and isolate the case from vibration and shock without allowing harmful oscillation. However, surrounding the case with foam might give you heat problems. If you support the case at the ends and allow for enough ventilation you may be OK.
pip is offline   Reply With Quote
Old 04-07-2004, 04:34 PM   #5
MP3DUB's CarPC Specs
MP3DUB's Avatar
Vehicle: 1993 VW Passat, 2006 VW Passat
My Photos: (9)
Why is the front of the car more dampened than the rear? AFAIK, it isn't.
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 04-08-2004, 02:46 PM   #6
My Photos: (0)
I have my mini-itx in my glove comparment and I didn't use any kind of padding (and I drive a sports car). You should be fine as long as you make sure everytyhing is tightly screwed in.
Rudical is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Battery Isolator solution? breimann Power Supplies 15 04-17-2005 05:45 PM
Mini-box.com delivers the tiniest mini-ITX power solution to date petesonline Power Supplies 1 03-04-2004 06:02 AM
Data logging solution for non OBD2 cars... doig General Hardware Discussion 4 11-06-2003 10:29 AM
laptop display solution cruzc_99 Off Topic 4 07-03-2002 09:44 AM
Possible solution to the inverter dilemma... gregulator Power Supplies 9 08-07-2001 09:38 AM
Sponsored Links
Ad Management by RedTyger
