The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 04-20-2004, 07:20 PM   #31
My Photos: (0)
How aobut these
http://www.frozencpu.com/cgi-bin/fro...rchspec=bulgin Frozen CPU - Bulgin vandal switches
Ted
tedpeer is offline   Reply With Quote
Sponsored Links
Old 04-20-2004, 09:22 PM   #32
My Photos: (0)
Ted
You da man, Ted.... a US site for the Bulgin ones... I am forever in your debt.
dug1967 is offline   Reply With Quote
Old 04-21-2004, 07:56 AM   #33
My Photos: (0)
Okay, this can't be right.... Can it?
I looked at the specs on these Bulgin Switches (with the cools LED ring) and it says "Max. Rating - 50mA @24VDC"......
Does that mean if I use this as a main power cutoff switch for the PSU which will have about 8A @ 12VDC going through it, I will melt the switch????
I mean really, these are hefty looking switches, I can't believe they can only handle 50mA @ 24 VDC, that is 0.0012 Watts.....
Old 04-21-2004, 08:14 AM   #34
Nic
Nic's Avatar
Vehicle: 1993 TX3 Laser
My Photos: (0)
so make the switch close a relay and run the pc off your relay
Nic is offline   Reply With Quote
Old 04-21-2004, 08:18 AM   #35
Banderon's Avatar
My Photos: (0)
dug, you can be our guinea pig. Try it and let the rest of us know if it melts.
Banderon is offline   Reply With Quote
Old 04-21-2004, 11:00 AM   #36
My Photos: (0)
Yeah, I thought of that, but I am so sick of wiring up relays.... I got so many frigging relays in this setup now.... it will probably sound like a click factory when I turn it on....
Maybe just try it out and see if it smokes.... $12... I have burned up more expensive things that that....
Old 04-21-2004, 05:27 PM   #37
Banderon's Avatar
My Photos: (0)
50mA - 8A.. that's not like "Oh, it's ALMOST there.." That's 16x the rated amount! I wouldn't throw away $12 on nothing just like that. Go for the relay, man.
Old 10-23-2005, 09:20 AM   #38
Hark's Avatar
Vehicle: 2000 BMW 328Ci (E46)
My Photos: (0)
So Banderon, did you ever find any switches that look like BMW switches? It seems like this place would do the lettering/stencil (maybe they can do it "reverse video" rather than just the black text on the lighted button).
Hark is offline   Reply With Quote
Old 12-15-2005, 04:34 PM   #39
Sylvester's Avatar
Vehicle: 1999 Mercury Cougar
My Photos: (0)
I'm a noob, so bear with me.....but what I want is to have a push-button (the Bulgin's look great) to START the carputer, and then have the carputer powerdown when the engine is turned off (a one way switch in other words...only to power on, not power off).
Would these bulgin buttons do this? I noticed it said momentary switch.....is that what this means?
If not, where can I find a button to do this, or how can I make this button do this? Thanks guys!
renew orleans
Sylvester is offline   Reply With Quote
Old 12-17-2005, 03:34 PM   #40
Raw Wave
Defiler's CarPC Specs
Defiler's Avatar
Vehicle: '05 Shadow Mica Matrix XR
My Photos: (1)
Yes the Bulgins will do this with an ATX PSU. Momentary means when it is pressed it creates the connection as long as you hold it down and when you let it go it acts as an open.
/////Alpine PXA-H700
/////Alpine MRV-F345
Aura MR62 (F and R)
Sansa Clip
All wires by Knukonceptz.
My Current MP3s
IamDefiler.com
Still have tons of parts for sale!!! MB's, CPUs, Fans, etc. PM me and I will send a list.
Defiler is offline   Reply With Quote
Sponsored Links
Old 12-17-2005, 03:41 PM   #41
Vehicle: 2001 Sebring Lxi Sedan
My Photos: (0)
http://www.frozencpu.com/ele-70.html nice switch but alittle expensive they gotem in other colors too. GL nm i saw u found the same switches sry
Jcarere is offline   Reply With Quote
Old 12-17-2005, 04:27 PM   #42
My man uses Levitra.
Peoples's Avatar
Vehicle: '00 Honda Accord Coupe v6
My Photos: (0)
Jcarere you can delete your post
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 12-21-2005, 04:15 PM   #43
Sylvester's Avatar
My Photos: (0)
I am a little confused still about what momentary switches do. I didi some searching online with not too many results.
So when you push a momentary switch, it makes contact (and in this case would complete the circuit to turn on the carputer), correct? But when the switch is released, would the carputer stay on, or would it then shutoff because the circuit is now open?
And just to clarify further, this switch could not be also used to power down the carputer, correct?
renew orleans
Old 12-22-2005, 11:02 AM   #44
Raw Wave
Defiler's Avatar
My Photos: (1)
all current (read post AT) power supplies and motherboards only need a quick short of two pins to turn, and kepp on, a computer. So, to take a momentary switch, like the Bulgen or any other switch you have in an ATX flavored case, press and release it and the computer will turn on and stay on.
Now to answer your question about turing the computer off by the same switch. The answer is yes as long as it's setup correctly. You can setup, in the OS, to have the power button do a number of things. I have mine setup so that when it is pressed and released the computer will shut down properly. i.e. close all apps and run the shutdown process. I also have the BIOS setup so that when I hold the power button for 4 sec. it totally cuts power and does a dirty shutdown. This is only for when the computer locks up.
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
Old 05-19-2006, 08:08 PM   #45
Grimoire's CarPC Specs
Grimoire's Avatar
Vehicle: 2003 Pontiac Vibe GT (Dent is fixed! XD
My Photos: (0)
Alright, all this makes sense, for a PC, but what about a laptop? How would I extend the on/off button from the laptop to say, my dash? And I know which options you are speaking of Defiler, and I would use them. I mean, laptops take how long to boot up? Get in my car, turn the ignition, press the button and go. Simple as that, have certain programs to start on boot, touch screen to start the muisc and wammo!
But how to extend the button? Any ideas?
Grimoire is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
linking into laptop power button corsamel General Hardware Discussion 18 09-06-2007 09:47 PM
Relocating computer power button King_Xerxes General Hardware Discussion 8 02-21-2007 09:15 PM
Exit button liquid_smoke Media Engine 1 02-04-2004 09:29 PM
PC power button problem BMp3W Power Supplies 4 10-12-2002 02:36 AM
internet button on my pc babas151 General Hardware Discussion 10 05-31-2002 02:41 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
