Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-17-2004, 10:52 PM   #1
dug1967
Illuminated Button
Okay, I have here and 'ed till I was blue in the face.... and I can't find a decent source for COOL looking pushbuttons with LED (colored) illumination.....
Does anybody know of a source for Cool looking push buttons with some kind of illumination.... and yes I have checked DigiKey and Mouser..... I have searched the computer mod sites and found nothing....
I need a Normally Closed push button, but could live with a normally open one if I had too....
Any suggestions would be most appreciated.
dug1967 is offline   Reply With Quote
Old 04-17-2004, 11:15 PM   #2
ML430's Avatar
ML430 is on a distinguished road
http://www.happcontrols.com/index.ht...in_switch.htm!
They primarily stock a myriad of arcade controls. I have bought many a joysticks and pushbuttons from them, I have been very pleased with their products and service...
1999 Mercedes ML430 - Epia M10000, OPUS 90w, 512mb, 160gb, Deluo GPS, SB Audigy 2 NX, 7" Lilliput TS
ML430 is offline   Reply With Quote
Old 04-17-2004, 11:25 PM   #3
Banderon's Avatar
Banderon is on a distinguished road
Damn.. those are expensive.
I'm actually looking for something similar. I want a button with integrated LED/light, and I want the light to be independant of the button. That way, for example, if I have a button for heated seats. I can press the button, and button would light up and seats would heat up. However, next time I turn the car on, the button and switch are off.
Banderon is offline   Reply With Quote
Old 04-17-2004, 11:34 PM   #4
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Google "lighted LED push button switch"
http://www.directron.com/push15135.html
http://www.itwasia.com.tw/e-switch.htm#3
http://www.rjselectronics.com/cms/ht...3bd415f84f9f8c
http://www.ottoeng.com/control/pushbutton_lp5.htm
I hope you find what you are looking for, Good luck
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 04-17-2004, 11:53 PM   #5
Banderon's Avatar
Quote: Originally Posted by TruckinMP3
I should probably have mentioned that I also want to insert a label into them.
But thanks for the help.. some of those I haven't seen before and they look pretty.
Old 04-18-2004, 12:07 AM   #6
Banderon's Avatar
Wait! Scratch that! I got an idea. My goal is to make buttons similar to those found in a BMW. They're pretty black rectangles with the picture of them of what they do, and when you press them an LED on them lights up.
I was just thinking... some of those illuminated pushbuttons you linked have more than one LED. I'm thinking I can print out a stencil of the graphic I want, and paint over the button with black paint. That way, the button looks like black plastic, except for the image on it that will shine through. And when I press the button, I can wire it to switch which LED is lit. So for example, normaly they can be white, but when pressed they turn red.
You people think that'd work? Or would the LEDs shine through the paint?
Old 04-18-2004, 12:14 AM   #7
dug1967
Thanks all, those are good links, have seen most of them... and unfortunately they are not what I am looking for....
There was a topic on here that I got started with, can't find it now... crap..... but it had a link to some metal LED ring illuminated buttons... they were cool, but only NO no NC... might just have to deal with them....
But also they were not quite right.... I just keep thinking there are more appropiate ones out there.... with all the case modding going on, and LED's being so popular in case modding, I just feel there is more out there....
I really need to find that topic, it gives a good idea of what I am looking for....
Old 04-18-2004, 12:27 AM   #8
Aftaab001's Avatar
Aftaab001 is on a distinguished road
what to you think of my one? check my carputer link below. one of the pictures got a start button for the carputer (as an overide just in case)
MG ZR CARPUTER (UNITED KINGDOM)
Aftaab001 is offline   Reply With Quote
Old 04-18-2004, 12:35 AM   #9
dug1967
Which picture shows it best... I didn't really see a good picture of a button... is 000 0360 the best? There is a lot of Blue Glow in that one, but really can't see a button
Old 04-18-2004, 12:36 AM   #10
Aftaab001's Avatar
000 372
Old 04-18-2004, 12:42 AM   #11
Aftaab001's Avatar
it's meant to be an engine start switch but i used it parallel with the ITPS switch to overide the ITPS just in case. cost me £17.00 roughly.
http://www.iconstyling.com/shopprodu...80952411689815
Old 04-18-2004, 12:47 AM   #12
Banderon's Avatar
OMG those are hot! Expensive as all hell, but so gorgeous!
I just might have to get some of those... but I wonder if they're too bright? There's not much info there on how the LED and the switch are wired... maybe I can throw in a stronger resistor into the LED's circuit to reduce the light a bit?
Old 04-18-2004, 12:50 AM   #13
Aftaab001's Avatar
do a search for " savage led switch" or simmilar. i dunno if you can get them in america. probably be cheaper than in bloody UK!
Old 04-18-2004, 12:52 AM   #14
Banderon's Avatar
If not, I'd import them. I'd get 3 or 4 of those just to mount them in a corner somewhere. Those'd get some mad "ooohs" and "aaaahs"...
Old 04-18-2004, 12:53 AM   #15
Aftaab001's Avatar
go on the shop link i posted up there. go to the airconditioning section. that little box is a relay Pust to make switch. 2 i/o. the brightness, just wire up a resistor or potentiometer in line and adjust to your preferance, that's what i done. by the way you get the little relay box with ll of them
linking into laptop power button corsamel General Hardware Discussion 18 09-06-2007 10:47 PM
Relocating computer power button King_Xerxes General Hardware Discussion 8 02-21-2007 10:15 PM
Exit button liquid_smoke Media Engine 1 02-04-2004 10:29 PM
PC power button problem BMp3W Power Supplies 4 10-12-2002 03:36 AM
internet button on my pc babas151 General Hardware Discussion 10 05-31-2002 03:41 PM
