excuse my ignorance but what do you mean by empeg?
anyway ... i don't think a capacitor will help you. for starters, in order to prevent speaker pop, you want your amp to turn off before, or at the same time as your sound card. if the sound card powers down first, you will get that wonderful pop. ... so doing anything to extend the amount of time the amp is on probably won't help.
even if that were the fix ... even a 1farad capacitor (those big ones you see in audio stores) would only provide you with power for a split second ... probably not even over one. search around in the threads regarding tank circuits and look for the equation Ricky posted a number of times.
you definately won't get any help from a cap you'll find at radio shack.
in my setup, i have my external usb soundcard and my amp's ignition wire both being fed from a relay, which is activated by the power cable coming off my ITPS. so the Soundcard and amp turn off at the same time. Additionaly, I have a EQ that my audio signal passes through which is hooked straight up to the ignition wire. So it turns off when the car turns off (45 seconds before the amp/soundcard turn off) so that also prevents the pop (no sound passes through the EQ when it's powerd off)
anyway ... i don't know your setup ... but find a way to turn your sc and amp off at the same time...
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
