Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-20-2004, 10:07 PM   #1
dark_muppet is on a distinguished road
Intel Motherboard for car???
I found this micro-ATX motherboard that I'd like to use.
http://www.newegg.com/app/ViewProduc...121-194&depa=0
I'd like to put a good videocard in teh AGP slot, 1 gig of ram, a 250 gig hdd, a cd/dvd combo and an intel p4 processor. I plan on building my own case using several fans (also running off the computer's power)
I'm worried about power. Can I run all this off a Opus 150W? If so, what's teh fastest processor I could run safely and the best agp video card I could use?
Thanks for your help in advance.
dark_muppet is offline   Reply With Quote
Old 04-20-2004, 10:18 PM   #2
dug1967
Well the first question is easy..... No way..... I feel that a desktop with the same components would come with probably at least a 400 Watt PSU.....
I am all for people doing what they want, so don't take this the wrong way, but why would you want so much computing power in your car???
For that much wattage needs I would think you only hope is maybe splitting the componets between two or three Opus 150W, or an inverter, which ain't the best in my opinion...
dug1967 is offline   Reply With Quote
Old 04-20-2004, 10:26 PM   #3
well I want the computer in my car to have some awesome graphics and speed for visualizations etc that will need smooth graphics. I figure something around a p4 2 ghz would be fine for processor.
Old 04-20-2004, 10:59 PM   #4
arkadiyp is on a distinguished road
Here are your problems with p4:
1) not enough power from a single PSU (DC-DC)
2) cooling that thing is going to be a pain in the ***
My advice if you want more power than EPIA try Athlon XP-M its half the watt requirement of a P4 runs on socket A. You get NForce2 MCP+IGP which will give you GeForce 4MX (not the greatest but decent), enough RAM and I think you'll be happy.
Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
arkadiyp is offline   Reply With Quote
Old 04-20-2004, 11:45 PM   #5
Sinorm is on a distinguished road
I have seen people mention DC-DC supplies in the 250W range on this forum, and you probably would need one along those lines. Maybe you could double up the sproggy design, and that would do it. The 1gb of RAM would definatly be a waste btw, the odds of you using that in a carputer are VERY small.
I agree with the above poster, the far more pocket-friendly, easier to install, and still very powerful system, would be to use the moble barton cpu.
Sinorm is offline   Reply With Quote
Old 04-21-2004, 12:12 AM   #6
theheel is on a distinguished road
are there any flex atx or mirco atx mainboards that take the athlon xp-m chip. I did a quick goodle search and did not find any?
theheel is offline   Reply With Quote
Old 04-21-2004, 01:00 AM   #7
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
Wow, that is a lot for a car computer. You don't need all that much to have nice video/visualizations/movies. I think my setup is even overkill (minus the HD) I would suggest cutting down a bit on the setup. Like was suggested an AMD XP low 2000s.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 04-21-2004, 02:26 AM   #8
Man
Man's Avatar
Man is on a distinguished road
No no, not a AMD XP (none of them are any good wattage wise). The mobile version, that fitts into a normal socket-A is what was being talked about, designed for use in laptops. Intels Pentium-M is a great CPU (also designed for use in laptops) as it doesn't take alot of power, and its got good performance per Mhz (ie a 1 ghz P-m is faster than a 1 ghz P4-m) however they do not fit into a standard socket-478, I have seen a mini-itx for a pentium-m goto http://www.commell.com.tw/Product/SBC.htm Scroll down near the bottom.
An AMD XP takes alot more power than an Intel P4
Edit: Gramatical stuff.
Man is offline   Reply With Quote
Old 04-21-2004, 09:34 AM   #9
P4_2.66GHz's Avatar
P4_2.66GHz is on a distinguished road
Scratch out AGP card from your list and go for it.
It will work with Opus 150.
2.6 GHz will work for certain.
Good cooling solution is required.
P4_2.66GHz is offline   Reply With Quote
Old 04-21-2004, 09:42 AM   #10
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
Any Socket A MB with a KT400a or better VIA chipset or nForce2 chipset will take an AMD-M CPU.
And I totally agree with what arkadiyp said.
Defiler is offline   Reply With Quote
Old 04-21-2004, 04:22 PM   #11
XENO's Avatar
XENO is on a distinguished road
P4 CarPC
Just a suggestion. Try looking at IDOTPC.com. Here's a mini-itx format that utilizes P4 chipset and will operate with 150w as long as you use the slimline cd-rom and laptop sized HDD, which are also available at this site.
http://www.idotpc.com/TheStore/Deskt...t.status=green
XENO is offline   Reply With Quote
FS: Casetronics C134 and EPIA M9000 Motherboard jusatry Classified Archive 13 05-17-2004 05:38 PM
For Sale: Intel D810EMO motherboard + Pentium 3 1GHz Dexter Classified Archive 1 10-06-2003 11:07 AM
Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant? smoldyr General Hardware Discussion 1 11-14-2002 08:56 PM
Ultimate Car PC motherboard, P4 power, Firewire, USB2.0 cproaudio General Hardware Discussion 15 10-03-2002 06:50 AM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 06:27 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
