Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-23-2004, 05:53 PM   #1
Bitflip is on a distinguished road
Power problems with car computer :(
hi, after weeks of getting everything together, and setup i was happy with the install untill i lost power!
To get started these are the details:
Car: Honda Civic 2004 sport
Computer - Shuttle SN45G, 80gb hdd, 2000xp cpu, wireless network
Invertor - Skytronic 300watt 600peak, - just the 12volt verison - http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=36799
FM modulator - hoping to replace with a sony AUX to adaptor
Noise filter on RCA's
Cable setup:
4AWG power cable from battery to boot with 30amp fuse at battery.
4WAG ground cable in boot
Relay via ingition (when car is on, power cable becomes live)
Anyway, the story goes like this......after days of testing and running the pc without anyproblems (but changing the setup to get the current power cables), the last few days the pc has been switching off.
So i checked everythink over, only to find that the invertor (only thing it can be) cut the power (10.2 volts) so the car has enough power to start up.
As per normal i got my voltmeter out and checked the voltage across the battery, and it was 12.3v. Before i started the voltage was about 14.5-15v. Check the little display on the battery and it was no longer glowing green, but a dark green/black colour. Since then i've left the pc off and AC so the battery can charge up again, but its reached about 12.9 and wont go much higher.
What i need to know is how can i fix this power problem?
I believe its either the alternator which needs uprating, or a better battery? If i was to buy a capitor, and place it parrell to the battery, would this help solve a few things or atleast make the power line more stable?
Also now that i've found a place that sells OPUS in the UK, if i was to get one would this solve my problem?
p.s. when i got the car new, the headlamps would dim, everyfew mintues when the car was on but idle/low speeds - when ever the fans kicked in, they would dim.
Bitflip is offline   Reply With Quote
Old 04-26-2004, 02:03 AM   #2
SteveC is on a distinguished road
That sounds as though your car battery has developed a bad cell and simply needs replacement - get a good brand heavy duty version and you should be fine.
Your alternator should be ok but keep an eye on the charging voltage as it's not unheard of for the diode pack to fail when the battery fails - a new alternator isn't that expensive however
Steve
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
SteveC is offline   Reply With Quote
Old 04-26-2004, 02:24 AM   #3
Crimson Tear is on a distinguished road
If your battery is servicable, test it with a hydrometer. But, seeing as how it has a float in it, it probably isn't. I would say that you need a new battery if the bubble is black (means that hydrolyte is dead). BTW, battery voltage should be 12.6.
Crimson Tear is offline   Reply With Quote
Old 04-26-2004, 02:56 AM   #4
thanks for your help, i'lll check the battery over to see if it is that.
Old 04-26-2004, 12:20 PM   #5
SjLucky's Avatar
SjLucky is on a distinguished road
I got the greatest idea ever. It will solve all your problems.
Take out the carputer, Toss the civic and get a real car.
Quote: Originally Posted by menudude View Post
thank you all for your help minus the useless post by sjlucky...
SjLucky is offline   Reply With Quote
Old 04-26-2004, 12:54 PM   #6
brrman's Avatar
brrman is on a distinguished road
well, isn't that the *** post of the year...
Car: 2000 Audi A4 Avant 1.8t
Carputer 2.0: removed. Back to stock.
brrman is offline   Reply With Quote
Old 04-26-2004, 02:01 PM   #7
frenchnew's Avatar
frenchnew is on a distinguished road
Thumbs up
Well replied brrman
He must be annoyed at being condemmed to drive a paddle boat (Mississipi)
frenchnew is offline   Reply With Quote
Old 04-26-2004, 02:03 PM   #8
frenchnew's Avatar
Your car must still be covered by Honda's Warranty, take it to your dealer to have it checked.
Best regards from Montreal
frenchnew
Old 04-26-2004, 03:15 PM   #9
P4_2.66GHz's Avatar
P4_2.66GHz is on a distinguished road
When the car is off, your battery should read 12.3V.
When the car is on (power supplied by the alternator), it should be 14.3-14.5V.
P4_2.66GHz is offline   Reply With Quote
Old 04-26-2004, 04:13 PM   #10
SjLucky's Avatar
I try my best to be an ***
and you need to leave my paddle boat out of this she has done nothing to you
computer in car Nuclei2v5x Newbie 12 05-19-2009 10:00 PM
Will this power a computer? Vicked Power Supplies 2 11-11-2003 08:40 AM
Ok, new car and new computer HELP rhurley General MP3Car Discussion 10 10-07-2003 03:01 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 02:42 PM
300 watt power inverter problems DaPyro General Hardware Discussion 6 03-10-2000 03:56 PM
