Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-21-1999, 02:03 AM   #1
CarMP3
Connecting Laptop Hard drives to PC Mobo
Hi,
Anyone out there has experience with connecting laptop hard drives to AT/ATX motherboard IDE connector? If it is possible to do it at all.
CarMP3 is offline   Reply With Quote
Old 09-21-1999, 04:38 AM   #2
Jiggy
Yes, I bought a $10 adaptor that converts the 20 pin IDE connector to the 20 pin connection that the 2.5 “ notebooks use. All the pins seem to be the same (following the traces on the PCB. The only difference besides the addition of two pins for power (+5 and Ground) seems to be the difference in header pin spacing. The PCB has a conventional power connector, and a LED with 6-inch leads attached to a two-pin header on the PCB.
I found mine at. WWW.NANOSYS1.COM
However, I am sure others sell them.
P.S. I bought this converter this spring after finding a 2 gig IBM hard drive! The Hard drive was buried in a pile of sand at the bottom of a melting snow bank in a parking lot at the University of Minnesota! The notebook hard drive, after my brother (without permission) backed up my family’s hard drive and formatting it, decided to “go up in smoke”.
-Jiggy
Jiggy is offline   Reply With Quote
Old 09-21-1999, 04:38 AM   #3
Jiggy
-Jiggy
Old 09-21-1999, 09:43 AM   #4
nfored
Does that mean your not using it anymore? I can't find one of those adapters listed on nanosys's webpage. I'll buy it from you if your interested in selling it.
nfored is offline   Reply With Quote
Old 09-21-1999, 08:09 PM   #5
Jiggy
I called them, they told me that you would have to call them and order it using a credit card [ (612) 331-3690 ]. One of the guy's there isn’t too bright, so if they tell you they don't have them they’re wrong. It is called a Micro IDE to IDE converter and costs $ 9.99. They are going to screw you on the shipping. Find out how much a one-pound box will cost shipped from Minneapolis, MN to your hometown. They figure it will be between $6 to $7.
My advice is to call around your hometown and ask all the computer stores if they can get them. I am sure it is going to be cheaper then $17 dollars. E-mail me if you still want mine. I have two but I will have to try and find them. martinmn@sprintmail.com
-Jiggy
Old 09-22-1999, 12:10 AM   #6
inmytree
Can anyone explain to me why the hell you would want to use a laptop hard disk with a normal PC??
inmytree is offline   Reply With Quote
Old 09-22-1999, 12:37 AM   #7
nfored
laptop hard drives are rated for a MUCH higher shock resistance while operational. so when i'm pulling 3 or 4G's in my car i don't have to worry about my music skipping. no, really i think its more of a concern for the health of the hard drive. technically hard drives shouldn't be used in most cars (because of the shock to the heads), or in my case because of the driving style of the driver. >;')
Old 09-22-1999, 11:47 AM   #8
CarMP3
Thanks all you guys for replying to my post with very informative answers.
Inmytree: laptop drives are smaller than normal 3.5" hard drives in size. And also like the other gentleman has pointed out they an withstand shocks better than regular IDE hard drives.
Old 09-22-1999, 11:47 AM   #9
CarMP3
Old 09-22-1999, 10:52 PM   #10
Frank Grayson
I think the main point of not using a laptop HD in a normal PC is the much higher cost.
for $130 you can get 16.8 gigs i don't think
that'll get you 6 gigs even for a laptop HD unless you find some really good deal.
By the way you'd be surprised just how much shock a normal HD can take if you mount it properly. $260 can get you 27.3 gigs heh granted the drive is considerably larger and
more prone to shock than a laptop HD but the storage space outweighs that problem in my mind (i've been running normal HD's for over 6 months under normla car conditions [NO OFFROADING or speed bumps at 90mph] and so far no problems)
-Frank Grayson
Frank Grayson is offline   Reply With Quote
Old 09-23-1999, 02:56 PM   #11
jjohnson
FRY's has an adaptor for using a laptop hard disk with a normal IDE cable for $6.99.
FYI:
- Laptop hard drives have power and signals all in the ribbon cable, so they have 44 pins instead of 40 like a full-sized drive.
- Laptop hard drives only require +5V to operate. You don't need to feed them +12V.
- Laptop hard drives are usually a few ms slower than their larger cousins (i.e. 12ms compared to 9.5ms)
--Jason
Johnson Interface Solutions
http://jump.to/m2pc
Jason Johnson
Yorba Linda, California
http://www.m2pc.com
M˛PC Phase IV - *** PENDING ***
jjohnson is offline   Reply With Quote
Old 09-24-1999, 06:06 AM   #12
snakebite
If your only reason for using a laptop HD is for shock immunity here is an idea, I have mounted my hard drive to one of those sony diskman car mounting plates, this provides plenty of shock protection, I have driven my ute along ruff old dirt roads, speedhumps, curbing, footpaths, performed circle work, had a little shag in the back all while my mp3 player was running. It has been in there for about ten months now and there are still no bad sectors on it
http://mp3gt.mp3car.com/
snakebite is offline   Reply With Quote
