Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-28-2004, 07:29 PM   #1
ToeRag is on a distinguished road
How to connect 2 inputs to my TAPE in?
I'm just starting to get into a PC in my car (PT Cruiser) I;ve got a system working pretty well, and plan on going all the way soon. However until I get some better touch screen software for my XMPRC I;m sticking with my Roady for now.
So here's my problem...
I've got my stock CD/FM Tape Stereo in my PT supplying the AMP and control for my speakers. The input through a TAPE adapter in the cassette drive. Not the best but until I get the $$ it's going to get me by.
So I have a 'Y' 1/8' mini stereo plug adapter that I use connect to the TAPE adapter, one to my PC lineout, the other to my XM Roady. When I want to listen to XM I plug in the mini and leave my PC off. and Vice-Versa. Can I Put some diodes in-between to block the direction of output to only go to the TAPE adapter? so I don't have to keep un-plugging the 1/8" plug?
What I want to do is leave them all plugged in all the time without worrying about a feedback, or damage to any component. I thought of a switch, but it's NOT a good solution right now. I will eventually switch to using my XMPCR through my PC but I have a though time waiting for my PC to BOOT befoe I get any audio... spoiled!
can anyone help?
ToeRag is offline   Reply With Quote
Old 04-29-2004, 08:25 AM   #2
falconey's Avatar
falconey is on a distinguished road
Seems you've ruled out the best solution. Radio shack has source selectors. They cost $$, but they are the best solution for this issue. You put all your inputs to the source selector and use the selector to switch between the different sources.
falconey is offline   Reply With Quote
Old 04-30-2004, 01:59 PM   #3
I haven't ruled it out... I didn't know they had anything... are they small? do they accept 1/8" mini plugs?
Old 04-30-2004, 02:08 PM   #4
archimense's Avatar
archimense is on a distinguished road
Have a look at auxillary input convertors here: http://www.logjamelectronics.com/auxchry.html
archimense is offline   Reply With Quote
Old 04-30-2004, 02:13 PM   #5
Jackso is on a distinguished road
Or, since everything is line level, you can just run them both.
You're not going to hurt anything by leaving them connected. You could in fact play both the XM and the computer audio at the same time, and still not hurt anything, it would basically mix the signals.
Another option is to use the line input of the computer to run the XM into, and use the line output to run to the cassette adapter. You would most likely then have to have the computer on all the time for the XM to work, but it's possible that some MOBO manufactures couple them some how, not too sure about that. But I do know that you won't hurt anything connecting 2 line level outputs to one another.
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
Jackso is offline   Reply With Quote
Make shift Line out From Old Car Tape Deck? BlkCroWe Car Audio 7 04-18-2004 01:03 AM
high level inputs and low level inputs, what does it mean? TiTUS General Hardware Discussion 4 09-28-2003 10:51 PM
PSOne monitor (again) how to connect to TV-Out Daninino LCD/Display 7 09-23-2003 02:32 AM
Does this sound like a bad tape? BLACKOUT General Hardware Discussion 3 03-28-2001 10:27 PM
tape adapter vs. rca sheriff General Hardware Discussion 5 03-21-2001 09:05 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
