Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 05-14-2004, 08:38 AM   #1
dug1967
Using Battery Charger to Extend Battery Life?
Okay, I have never really had a good understanding of amperage and current flow.... Here is the issue...
I have the CarPC all together in it's case, and have been running it off a 12VDC lawn mower battery as I work on the final hardware issues. It would be very difficult to hook it up to a standard ATX PSU right now and run it from AC.
But now I have to reformat the HD and get the software the way I want it. But this lawn mower battery does not have enough life to do a full HD format and install Windows before the voltage drops too low and it shuts down.
If I had the computer running off the battery, doing what I said above, and attached my car battery charger to the lawn mower battery, would I fry something in the CarPC?
The charger has two current setting (2A and 10A) and I think this means it forces 2A or 10A to the battery and whatever else might be hooked up..... I know the system is drawing more than 2A, so it seems to me like it would extend the battery life so I can get the software stuff done before the battery runs dead. Now maybe the 10A setting would be too much, I don't know....
The whole deal just makes me nervous.
What do you think???
dug1967 is offline   Reply With Quote
Old 05-14-2004, 09:10 AM   #2
MeanGT's Avatar
MeanGT
I used to run my Heavy load 12v devices directly of my car battery charger. I would set it to the 50-amp jump start setting. Just becaues the charger is putting out up to 50 amps, doesnt mean you will over-power your PSU, the PSU will only take how much amperage it needs. If you think about it, a car battery can put out many hundres of amps and cause no harm.
The only problem I ran into using the battery charger, is that the power output is quite a dirty signal, so you may get interference or noise when using it.
My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
MeanGT is offline   Reply With Quote
Old 05-14-2004, 09:15 AM   #3
dug1967
Thanks for the info MeanGT.... I just can never comprehend current.... I was under the impression that Battery Chargers "Forced" current to whatever is attached to them...
But I guess not based on you using a 50A setting... by the way, what do you mean by "Heavy Load 12V devices"????
Old 05-14-2004, 11:55 AM   #4
MeanGT's Avatar
MeanGT
I frequently find myself repairing things such as head-units, and amplifiers for myself and friends, and rather than lugging in a 12v battery to test them, I just bring in my battery charger. A true power supply that puts out enough current to handle these items can be quite pricey.
Can I put an extra battery in my Chevy? Mastiff Power Supplies 14 11-04-2008 12:45 PM
Battery based tank circuit (tested) Ricky327 Power Supplies 241 02-13-2008 05:43 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
laptop battery pack charger? mrzigzag Power Supplies 0 12-07-2003 07:36 AM
Laptop battery died jol General Hardware Discussion 6 08-22-2003 04:55 AM
