Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 05-14-2004, 02:50 PM   #1
ashbosh's Avatar
ashbosh is on a distinguished road
Question mobo witout resume on power loss and how power button works
Hi. I'm using this mobo which doesn't seem to have resume on power loss feature. The attched image shows the power option that show up in the bios. I pulled the power cord off and connected back on to see if the pc starts. But it did not work. The bios shows wake on ring/lan/RTC. I don't know how that works. I think the mobo should support this "resume on power loss" feature to turn on when the power is re-applied to the pc. Does anybody know some trick/mod to make it work?? Is it possible to somehow send power on signal to mobo when the car is started. Maybe a relay or something? How does the power button work?? Any help/suggestions are appreciated. thanks
Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
Holux G210
03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
ashbosh is offline   Reply With Quote
Advertisement Sponsored links
Old 05-15-2004, 12:43 AM   #2
ashbosh's Avatar
Thats what I found on the net...
The push button sends a 5-volt signal to the power supply to tell it when to turn on. The power supply also has a circuit that supplies 5 volts, called VSB for "standby voltage" even when it is officially "off", so that the button will work.
So does it mean the pins where the power button is connected, has 5volts across and the power button either shorts it when pressed or its already shorted and the power button opens the ckt when pressed? My understanding may be flawed, I don't know. I tried to measure resistance of the power button(thinking its simple switch), but I got infinite resistance in both states. I'll check the voltage across the switch and resistance tomorrow.
I hope somebody here knows how this stuff works.
Holux G210
Old 05-16-2004, 07:01 PM   #3
NitroNic's Avatar
NitroNic is on a distinguished road
ATX motherboards, as long as their power supply is powered, and attached to the motherboard (and the switch on the power supply is in the "ON" position), indeed are powered. Most of them have some sort of LED on them to indicated that they have power, and some also indicate that they are in standby mode.
The power switches for ATX's are just momentary close, normally open switches. All it does is short the pins, which signals the power supply to turn on. To tun it off, the motherboard sends another signal to the power supply that indicates "turn off now!!" , or you can hold down the same power button for a few seconds, and it will also turn off.
I haven't researched this much, but you might look in the section called "power supplies," they probably talk about good ways for turning them on and off automatically.
If you just want something simple, you could have a relay from your on or accessory switch, and when energized, it will start a timer to close the power button circuit for a short time (half a second), and then open the circuit right after. And of course, when you turn the car off, cut the power to the computer...unless you're running windows or something, in which case you would need to find some shut down controller (again, search in the power supply section) to safely shut down the machine.
Hopefully this will help some.
Nic
NitroNic is offline   Reply With Quote
Old 05-18-2004, 10:49 AM   #4
ashbosh's Avatar
Thanks Nic,
I did check the voltages and all and found out the functionality of the power switch the hard way. I'll probably mount the power switch somewhere in the dash. But as you said if I could use the relay, that'll be super. I'm still searching. But if you have any info on it pls let me know.
Holux G210
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
Feature Request: Shutdown on battery power / Hibernation support in shutdown menu Confused MediaCar 3 11-14-2003 08:47 AM
FS: Celeron 500, Mobo, Ram $40 surfer6262 Classified Archive 1 03-27-2003 08:34 AM
Sorting out power issues MattW Power Supplies 6 07-16-2001 04:41 PM
Brief power loss between ACC and start Destin General Hardware Discussion 20 01-26-2001 11:12 PM
