Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-06-2000, 10:57 PM   #1
blkdragon6
Post Mobo IR connectors
Hello,
I was wondering if it would be possible to use some kind of device that hooks up to the IR connectors on the mobo (like http://www.actisys.com/act210.html) and be able to use the IR winamp plugins and other various IR applications. The reason why I ask this is because I need the two serial ports and I'm not sure if the serial communication is different than the communication with the IR connectors, or whatever. I'm not really up with IR devices so any info would be greatly appreciated.
www.geocities.com/blkdragon6
blkdragon6 is offline   Reply With Quote
Advertisement Sponsored links
Old 07-07-2000, 12:42 AM   #2
pcman
Post
no you cant
cant remember the reason why
cheers pcman
colecting new parts
installing into new toy
1975 td cortina wagon
12.1" lcd touchscreen
10.1" lcd
just the essentials :)
arr the fun starts again
pcman is offline   Reply With Quote
Old 07-07-2000, 02:55 AM   #3
^insane
Post
Wrong, this can be done. You just have to make sure that you use a plugin designed for this, and not for serial ports.
^insane is offline   Reply With Quote
Old 07-07-2000, 03:09 AM   #4
blkdragon6
Post
Thanks for clearing that up. Is there any software (for winamp purhaps) that would be able to use the mobo IR connectors? Or would it be too far fetched for something that can act as a translation layer between moboIR and serial IR signals?
Old 07-07-2000, 09:22 AM   #5
^insane
Post
I found this at the plugin/skin section at www.winamp.com:
http://www.winamp.com/customize/deta...mponentId=7914
I have no time for reading the text now, so maybe this is what you need, but then again, maybe it isn't. You'll have to see for yourself.
Old 07-07-2000, 10:26 AM   #6
pcman
Post
that plugin wont work its for a lil ir device thats simple to make ive made one just been to busy using my comports to test/play with it
cheers
pcman
colecting new parts
10.1" lcd
Old 07-07-2000, 02:23 PM   #7
blkdragon6
Post
Aye, I know what you're talking about pcman. I was thinking about just putting together something like this, but I'm trying to get away from using another serial port, blah. Was worth a shot though.
