06-07-2004, 04:24 PM
#1
Question about Opus and Power Buttons
Ok, you know how motherboards have pins that you plug the power and reset switches from cases into? Well, if you use an Opus do you still need to have a power button or does the Opus automatically send on a turn on signal?
Lastly, where is a decent place to pick up power and reset switches along with leds and wires w/o buying an entire case?
06-07-2004, 04:30 PM
#2
Vehicle: Mazda 6
Opus connects to those pins to allow power on/off on ignition.
Buttons -> search for bulgin .. or visit any 'pc modders' site.
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
06-15-2004, 07:03 AM
#4
Vehicle: Audi A4 2.4 V6 and 1972 MGB Roadster
Those Anti Vandal switches from Bulgin are sweet, but as they are a specialist item, they are of course more expensive.
For standard (and cheaper) switches look somewhere like radio shack in the US or Maplin in the UK.
06-15-2004, 07:19 AM
#5
Vehicle: 2000 Ford Taurus & 2001 Ford Focus ZX3
Quote: Originally Posted by Mears
Dude, $20 for a friggin button? That is outrageous. There has to be a cheaper alternative.
You could, of course, go to Auto Zone or somewhere and pick up a cheap push button switch for a few bucks. It, however, is not going to look nearly as good as what that switch does. Plus that switch would make for a good center of attention. So you may have to do without eating at McDonald's a few times to pay for it but think about long term affects instead of your wallet right now.
IMHO
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
06-15-2004, 02:31 PM
#6
Well do any of these options come with the necessary pin headers? Every switch I've seen is just the switch itself and no wire + pin header included.
06-15-2004, 03:28 PM
#7
Jesus Freak
Vehicle: 2006 Mazda Mazdaspeed 6 GT
What if i want to to put that vandal switch inline with the wires comming out of the opus to the motherboard. Will this work?
07-18-2004, 02:55 PM
#8
My understanding is that the particular Blugin illuminated switch listed in the above link is a momentary switch. I want to use it to power up my Opus also but I don't think it is gonna to work because I think it needs to be a push button that would stay down (not momentary).
Please correct me if i'm wrong. W/ that said, does anybody know where to get one iluminated w/ a ring like that but it is a stay down push button?
07-18-2004, 03:39 PM
#9
Vehicle: 1997 Geo Tracker 4DR 4WD
all ATX boards need a momentary button because that is how the power works - this solved the problem that AT boards had...
http://linear1.org/gm/archives/00000180.php
don't let a day go by without finding some wonder in it...
07-18-2004, 04:26 PM
#10
Quote: Originally Posted by saikano
that's a good read. THanks for the link.
However, power the opus is different than power an ATX mobo. i know that an ATX mobo requires a momentary switch, but opus is the exact opposite...
07-18-2004, 04:32 PM
#11
Raw Wave
Vehicle: Jeep GC
Nope, the Opus is an ATX PSU! Well, yes you're right, sort of. The Opus SDC circuit does the job of the momentary switch to the sys board, which then switches the PSU on. But to tell it to do that, you need a constant(while you want the psu on) +12v, usually taken from the ACC wire.
07-19-2004, 01:39 AM
#12
so i 'm still a little confused, in order to power an opus the yellow line (pin3) needs to be connected to the Ignition or On/Off switch and back to the +12. (as described in the manua below)
http://www.letscommunicate.co.uk/car...-xx09-lit1.pdf
Please see the wiring example on page 1. I don't suppose I can use this momentary button to get the job done, can i? I really like the button, but I think it calls for an On/OFF switch to control the the PSU, not a momentary switch.....
let meknow if i am way off base.
07-19-2004, 02:48 PM
#13
Raw Wave
Vehicle: Jeep GC
You're on base! To tell the Opus to power the computer you need +12v on pin 3. When you take +12v away from pin 3, the Opus will tell the computer to shut down (after a certain time limit). So, you need a constant switch not a momentary one.
07-19-2004, 02:55 PM
#14
Vehicle: 2007 Mazdaspeed6
is this PDF the same setup as a 150 watt Opus?
2007 Mazdaspeed 6
07-19-2004, 03:10 PM
#15
Raw Wave
Vehicle: Jeep GC
Why don't you go look at the 150w Opus PDF, see products on this site!, and tell us.
| Thread Tools |
| Display Modes |
Linear Mode
