Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-08-2004, 04:32 PM   #1
AEFL92 is on a distinguished road
Relocating Portable DVD Remote Sensor...
I’m going to be using a portable dvd player (Apex PD-450) for playing mpeg, mp3, wma, vcd, an of course dvds. I’m going to be tucking it away in the glove box…and not mounting it anywhere permanently because I want to be able to remove it for use outside of the vehicle. I have everything covered except for remote sensor relocation. The unit will get 12v off the ignition, and all other connections will be detachable. The only problem is with the remote sensor.
I want to keep the factory remote sensor intact, because I’ll want to use the remote with it when it’s out of the car. I planned on soldering to the board, and connecting a second sensor that would stay wired in the car, but able to be detached for unit removal. I came up with two ideas…but let me know if there’s an easier way I’ve overlooked…
Option 1: Find another Apex sensor. Using my original plan of running dual sensors, one for the car hidden, and one built in for using outside of the car. Does this sensor have to be an Apex sensor? How can I tell what will work with the provided remote? Where could I find another compatible sensor?
Option 2: Find another Apex remote (I don’t care if it is hardwired, I can keep the remote in center console)…AND wire the remote directly to the input of the other sensor. Can this be done? Will it pickup the signal the same as it would if signal was being transmitted through the two sensors facing each other?
Thanks for any input…ideas…advice…etc.
1992 300ZX 2+2...Stage III NA
7" Monitor...in search of something to use it for...
AEFL92 is offline   Reply With Quote
Old 09-10-2007, 04:03 PM   #2
comp98 is on a distinguished road
IR Repeater. You will need a Xantech connecting block, power supply, and flashers (for the IR). These are commonly used in home AV and are relatively inexpensive. Do a search on google to find out more. GL
comp98 is offline   Reply With Quote
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
Automotive Security Maeveth General MP3Car Discussion 18 04-07-2004 02:33 AM
psx controller hack to ps2 dvd ir remote Jeffro General Hardware Discussion 2 07-22-2002 11:32 AM
8.4" Touchscreen LCD, 7" Wide LCD & portable DVD player with TV Tuner nolmscheid Classified Archive 4 03-16-2002 02:32 AM
portable dvd solution? mr0range General Hardware Discussion 2 02-03-2002 09:57 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
