The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 06-12-2004, 07:26 PM   #1
coachreed's Avatar
Vehicle: 2000/Isuzu/Vehicross
My Photos: (0)
Griffin PowerMate? Can't get it to work... help please!
I purchased the Griffin Technology PowerMate on eBay and received it today. It didn't come with the installation disk but I quickly found software on the Griffin Tech site... DL'ed it and installed it... I have been jacking around with the thing for quite awhile today and have had NO luck. When I first plugged it in, the light was pulsing slowly... now the light is on solid... I have tried plugging and unplugging it several times, uninstalled and reinstalled the software a couple times and messed with all of the settings. STILL no luck! I am wondering if the software I DL'ed from Griffin (1.5.2) might be some kind of patch or something that needs to be installed over the OEM install from disk (if that makes any sense)... Any suggestions? I plan to continue messing with this thing ALL night until I get SOMETHING out of it... I assume that since the computer recognizes me plugging it in and unplugging it, and the fact that it lights up, that it ISN'T a bad PowerMate... I wanna figure it out ASAP so I can rest assured that I didn't get taken. Thanks in advance. TTYL!
Coach... aka Randy!
coachreed is offline   Reply With Quote
Sponsored Links
Old 06-12-2004, 07:45 PM   #2
coachreed's Avatar
My Photos: (0)
If anyone here has the PowerMate and the original installation CD, is it possible to copy the "PowrMate.inf" file in the drivers folder and possibly send it via email? That is the ONLY thing so far that I have found that I could do because I don't have the original CD. If anyone can help a brotha out... please, PLEASE email it to me... rreed17@kc.rr.com
TTYL!
Coach!
Old 06-12-2004, 09:28 PM   #3
wkolodny's Avatar
Vehicle: 2001 Ford Sport Trac
My Photos: (0)
See this link: http://www.griffintechnology.com/sup...PM-PC-004.html
Don't Fear The Gurkey
Click here to check out My Setup
wkolodny is offline   Reply With Quote
Old 06-13-2004, 12:07 AM   #4
coachreed's Avatar
My Photos: (0)
Thanks for the reply... but... I had already read that page... I have searched my computer and figured if it was installed correctly, I should be able to find the PowrMate.inf file, correct? Well... not anywhere on my puter. Anyone here have the PowerMate? If so, and IF you have your installation CD available... I'd REALLY appreciate it if you could afford a copy of the PowrMate.inf file. Or, I would like OTHER suggestions.
TTYL!
Randy
Old 06-13-2004, 06:17 AM   #5
wkolodny's Avatar
My Photos: (0)
TTYL!
Randy
I downloaded the drivers from griffin and installed them and they came with the PowrMate.inf file. I can send it to you but there must be something you are doiing wrong if you installed it and cant find the file. Running XP?
Old 06-13-2004, 06:26 AM   #6
Vehicle: Austin Rover MINI Mayfair Mk2, 1986
My Photos: (0)
Hi coachreed,
I had the same problem at the beginning. My Problems (think so) caused because i have a USB keyboard and Mouse. I think the Powermate driver has Problems when there are more HID-Interfaces than his owne. I unplugged any HID-Interfaces and then only plugged in the Powermate. And than it worked. After this you can pluggin the Keyboard and Mouse. It should be working. I have the same Driver (1.5.2) from the Website. Sometimes the Powermate don't worke again and I must restart the procedure with unplugging and then plugin the Powermate...
P.S: Sorry for my english
luebke01 is offline   Reply With Quote
Old 06-13-2004, 06:58 AM   #7
coachreed's Avatar
My Photos: (0)
I DLed the software from the Griffin site and ran it. It automatically checked for updated software and then installed. I let it install in the default location and when it was done, it confirmed that it installed successfully. The problem with looking for the .inf files is that there is only the one programe DLed... the .exe file. If you have a separate .inf file DLed, I'd like to try that if you don't mind sending it my way... please? rreed17@kc.rr.com
Quote: Originally Posted by luebke01
Hi coachreed,
I appreciate your info... I'll try that out. Right now, I am setting it up on my home PC just for the sake of testing it... I have a couple other USB HID devices plugged into it. I'll try your suggestions. If this takes care of it, I hope I can overcome this with the carputer since my install will be completely in the dash... don't know how I'm gonna go about unplugging and plugging once its all said and done. The only thing so far on my carputer setup that might be USB HID is one of my touchscreens... but we shall see. Thanks a bunch... and btw... your english is just fine...
Coach
Old 06-13-2004, 07:03 AM   #8
wkolodny's Avatar
My Photos: (0)
Coach
When you run the exe it creates those other folders. Browse your hard drive after running it and you will find the file. I had the same issue with multiple HID devices. Same fix worked for me.
Old 06-13-2004, 07:48 AM   #9
coachreed's Avatar
My Photos: (0)
OK, I unplugged ALL of my USB HID's... rebooted... plugged my PowerMate in... and guess what... it installed and initialized just fine... the problem is that when I plugged my USB Optical mouse, it caused some problems... I unplugged the mouse... no good... unplugged the PowerMate... plugged PowerMate back in... no good... unplugged powermate... rebooted... plugged PowerMate in... works great... but if I reinstall my mouse... the Powermate works fine UNTIL I reboot... UGH!
Now, with my carputer, the only other USB HID at this point will be my secondary touchscreen monitor (assuming I get it to work correctly)... but if they won't play well together... this isn't gonna be very convenient. Is there any way to force USB devices to initialize in a certain order? I guess this is a price to pay for a device that was originally meant for Mac...
Anyone out there have multiple USB HID's without ANY problems? If so, what devices do you have attached? Thanks in advance.
Randy
Old 06-14-2004, 07:14 AM   #10
TaylorMade's Avatar
Vehicle: 2K1 Yukon XL Denali
My Photos: (0)
I have the powermate and the touchscreen running with no problems at all. In fact I have 7 other USB devices running with the powermate fine. I have a lilliput, an Earthmate GPS, a keyboard, a sound card, wifi card, a usb hub, and one last thing that escapes me.
Denali XL
Carputer yanked from the Jeep and installed in the Denali...pics coming!
Check the old one here
TaylorMade is offline   Reply With Quote
Sponsored Links
Old 06-14-2004, 07:34 AM   #11
wkolodny's Avatar
My Photos: (0)
Mine works fine with a Lilliput Touchscreen, an IFree USB keybaord and mouse, and the Griffin. Only issue is that every once and a while it shows up as an unrecognized USB device. Its pretty random. Usually after the PC has been powered down without properly shutting down XP. I use hibernate mode instead of shutting the PC down and rarely have the issue.
The quick fix is to run the Device Manager and re-install the griffin drivers. I never have to reboot when I do this. Device Manager can be more easily run by launching devmgmt.msc - just create a shortcut to the file and launch it at any time. It is located at: c:\windows\system32\devmgmt.msc
I put a shortcut to it in my quick launch list so its easy to get to.
Old 06-14-2004, 01:07 PM   #12
Marsupial's Avatar
My Photos: (0)
wkolodny - where did you get your iFree? I have one and cannot find a second one for friends who asked to get one.
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
Old 06-14-2004, 01:09 PM   #13
wkolodny's Avatar
My Photos: (0)
I bought mine on ebay but I found a link for one here:
http://www.advantage-computers.com/p...S&StockNo=1498
Old 07-03-2004, 02:46 PM   #14
My Photos: (0)
I found no way to make the powermate work with any of the computers I have with an Logitech USB MX-500 mouse. Still interested in it working though but I won't give up its functionallity for the powermate though...
BrotherMaynard is offline   Reply With Quote
Old 07-03-2004, 05:44 PM   #15
fluffy2097's Avatar
Vehicle: 93 Honda Accord SE
My Photos: (0)
http://www.griffintechnology.com/sup.../PM-PC-006.php
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
fluffy2097 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
My 2001 Sport Trac Install wkolodny Show off your project 84 01-30-2008 10:18 AM
Suggestions / Requests LESLIEx317537 FrodoPlayer 89 07-29-2004 12:23 AM
Has anyone gotten a sproggy to work with EPIA boards? rbarr110 Power Supplies 26 05-10-2004 06:33 PM
Griffin Powermate volume control help bklynkaos Input Devices 3 02-08-2004 09:48 PM
Will the Toshiba LTM10C021 (10.4") LCD work ok with an AD2 (standalone) controller? pooshda LCD/Display 4 11-18-2002 08:59 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
