Quote: Originally Posted by Curiosity
Batmanatthenewb has some good pics at
www.samshomepage.net in Version 3. He uses the case screws through zip ties, screws those into the back of the case front and then just pulls it all down. I think that's the best design since those holes on the board don't line up with anything. It also looks like velcro between the LDC and the board to keep it from moving around.
Thanks for the compliament. Cool thing is, if I cut the
one ziptie that pulls the other four together, I have complete access to work on the unit. As far as the board I used four of the plastic motherboard support posts. You know, the ones that support the center when there is no brass post/screw setup. Put em in and added a little hot glue to keep em there. When I zip tie it all down, the board becomes a solid piece with the screen. I was real scared of the movement, and this worked out to be the best system I could come up with. The velcro is from my first attempt to attach the board to the screen.
Beware, If you attach the velcro to the center portion of the screen, when you start to pull the pcb off, it will pull on the "silver" lining on the back of the monitor, and it does pull out. But, you can slide it back in. So, if you do use the velcro route, make sure your attachment points are on the edge of the screen, not the center.
Batman
Batman@TheNewBatcave.com
AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
www.Cars-N-Computers.com
