Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-06-2004, 11:48 AM   #1
jrich523 is on a distinguished road
Internal USB Hub?
Do they make an Internal USB hub? i will need a hub for my USB items but i dont want to buy a normal one for two reasons
1) im going to crack the case open anyways, going to mount it to a panel in the car to make it look clean
2) i dont want to have to splice the power for it. would like to just use one of the power supply hookups (HHD/CD power plug)
any suggestions?
I dont really have the ability to make one, my electronics skills are weak..
jrich523 is offline   Reply With Quote
Old 07-06-2004, 12:17 PM   #2
krystar is on a distinguished road
huh? why would u need an internal hub? if you have a m10000, you have 2 on the back and 2 more on the header. most other motherboards have extra usb's on the hedaer too.
1) fine....then mount the usb hub on the same panel too.
2) so get an unpowered usb hub.
krystar is offline   Reply With Quote
Old 07-06-2004, 12:48 PM   #3
archimense's Avatar
archimense is on a distinguished road
You can buy a PCI card with more USB ports.
archimense is offline   Reply With Quote
Old 07-06-2004, 01:50 PM   #4
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
Do you mean one that stays inside the computer case? If yes, then you could take a small USB hub and tap into the 5V molex connector and power it that way.
Defiler is offline   Reply With Quote
Old 07-06-2004, 02:27 PM   #5
m3rdpwr
They also have the 3.5" drive bay hubs.
You could simply remove it and put it internally as well.
-Mario
m3rdpwr is offline   Reply With Quote
Old 07-06-2004, 04:04 PM   #6
im going with the nano board when it comes out.. so 2 on the back and 4 on board.. it will all be built in to the glove box (space limitations, no case, custom cover)
It will have a CF reader and a smart card reader.. there goes 2 of the 6 USB ports.. sort of a waste for just readers..
there will be a lot more USB stuff.. GPS, ECU hookup, multiple cams (might use a home security connector CCTV?) FM receiver.. radar detector.. and i was going to mount a few (at least 1) to the front panel for connections (USB key chain or such)
it doesnt HAVE to be powered, but i was going to use the hub for the ones for the front panel stuff which depending on whats plugged in to it MIGHT need power.. so... power it now, no problems later..
the 3.5 drive bay sounds like just what im looking for, thanks.
Old 07-07-2004, 12:07 AM   #7
d_sellers1's Avatar
d_sellers1 is on a distinguished road
Alot of the internal 3.5" drive bays have a USB header. This is what will be used to connect the drive to the USB on the board.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 07-07-2004, 06:05 AM   #8
m3rdpwr
Derek
True, he just needs to make sure he orders a hub version...
These look like you connect 1 or two in and get 4 out.
http://www.everythingusb.com/hardware/USB_Hubs/
Inquire and see...
-Mario
Old 07-07-2004, 07:18 AM   #9
http://www.everythingusb.com/hardwar...rt_Bay_Hub.htm
only its self powered...
I know when i used a USB hub before i ran in to power issues with a cam and a few other things on it.
I guess i could use this for the CF/smart media reader and for the free port on the interface..
great.. thanks guys..
Old 07-07-2004, 08:34 AM   #10
Mac Car Moderator
kandyman676's Avatar
kandyman676 is on a distinguished road
i knows you have space problems, but a PCI USB card will be much more simple and is already self powered..
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 07-07-2004, 08:44 AM   #11
yeah but im waiting for the nano board.. cuz of that space thing... and well.. it says it has a "mini PCI"
im not exactly sure what that means.. but.. my guess is there isnt any mini pci USB cards yet..
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Power for usb hub bklynkaos General Hardware Discussion 3 01-24-2004 06:45 PM
wireless usb kb + mouse + hub idea crippy Input Devices 4 10-12-2003 07:06 PM
USB Sound and Bus powered hub Suprapc General Hardware Discussion 10 04-21-2003 04:21 PM
