Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-23-2000, 04:49 PM   #1
jumpoint
Lightbulb ATX auto power on
Is there any way to get an ATX motherboard to automatically power on when power is applied to it if there isn't such a setting in the BIOS? I know there are MB's that have a setting like the in the BIOS, but mine doesn't, and it's a pain to open the trunk every time and power it on.
jumpoint is offline   Reply With Quote
Advertisement Sponsored links
Old 01-23-2000, 06:10 PM   #2
Snupha
Lightbulb
Find the motherboard power-on pins (which the power-on switch connects to). You can either lengthen the old switch, or use a totally different switch (single pull single throw) The motherboard just needs a short connection between these two pins. I figured this out by taking a peice of soder and using it to connect the m/b pins.
Snupha is offline   Reply With Quote
Old 01-24-2000, 02:55 AM   #3
jumpoint
Thumbs down
This doesn't work. It's the equivalent of holding in the power button. Any other ideas?
Old 01-24-2000, 02:21 PM   #4
Probedude_2000
Thumbs up
Check back with me in a week. I am working on a modification to my powerup/powerdown board to have a small onboard relay that is momentarily activated for turning on ATX motherboards. See http://www.dschmidt.com/autooff.html for the current version of this powerup/down board.
Dave
Probedude_2000 is offline   Reply With Quote
Old 01-24-2000, 10:35 PM   #5
Registered User
spud42's Avatar
spud42
Lightbulb
how about a relay where the coil is powered from 12 volts but with a resistor/capacitor network powering the coil sothat it takes a little time for the coil to energise and short the relay contacts. time delay is 5 times the r c time constant.
just an idea hope it works...should do...
NISSAN 180SX SR20DET 2lt TURBO 5 spd , gigabyte ga5ssm mobo,AMD k6 ii 450 Mhz,128 meg ram,4" sharp lcd,40 gig Hdd. IRMAN WinAmp ,TinyXP.ipaq4700 ,WM 6.1 ,4 Gig CF,TomTom 6,TCPMP edited 23/9/2008
spud42 is offline   Reply With Quote
Old 01-25-2000, 03:56 AM   #6
nevb
Unhappy
Hi all,
I found a couple of circuits at the websites below that may just do what we want here! Have a look....
http://www.aaroncake.net/circuits/relaytim2.htm or http://ourworld.compuserve.com/homep....htm#delay.gif
Nev.
[This message has been edited by nevb (edited 01-25-2000).]
Nev.
Squeezing MP3 technology into a Mazda MX5
Web: http://www.neddynet.co.uk/mp3
Email: nevb@lycos.co.uk
nevb is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
