Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-13-2004, 02:47 PM   #16
some old CD drives had master, slave, cable select, and single. 4 choices. WD is no jumper for single. most maxtors don't have a single setting.
turbochris is offline   Reply With Quote
Old 09-03-2004, 12:35 PM   #17
acetaminophen's Avatar
if it is set to master it means that there is also a slave so it looks for it. If there is one in a few seconds it will continue booting up. If there is none it gets hung for a few seconds extra looking for it. Setting it to single makes it so that it knows there is only one hard drive.
acetaminophen is offline   Reply With Quote
Old 09-03-2004, 12:50 PM   #18
Jeremyvnc's Avatar
Exactly and cable select selects the drive that is last on the ide (EIDE) cable as the master and the other(s) as slaves of it. If your driver doesn't have a "single" setting, set it to cable select and you should get faster boot up times. Reason for that is that the computer has already searched the entire cable and knows the location of the drives when it finds the master. I usually set my drives to cable select unless I can manually configure the drive specs (heads, sects, ect) in the bios (at which time I make them master and slave).
[edit]Just rememebered that to be able to use the cable select feature your IDE, EIDE, or UltraIDE must support the cable select feature.[/edit]
If you didn't have fun when you were living, were you really alive?
{[¤¤¤X-----------------]} 25% Complete (Plan Made, awaiting funds)
Jeremyvnc is offline   Reply With Quote
Laptop Hard Drive in carputer... Powers Newbie 7 05-08-2004 10:37 PM
Laptop Hard Drive Problems Powers General Hardware Discussion 0 04-28-2004 07:21 PM
All-electronic flash drive and solid state hard drive Typhoon747 General Hardware Discussion 12 12-12-2003 02:20 PM
How does a hard drive just die? Sleeka General Hardware Discussion 10 08-08-2002 02:27 PM
External notebook hard drive help mtmsol General Hardware Discussion 4 04-18-2002 12:24 PM
