hey saikano
are you still using your stock speakers?
do you plan on upgrading them?
how many speakers do you have?
A 55 amp alternator is not a "bad" as you may think. If you are lucky enough to find a 20x4RMS amp (assuming you have 4 speakers) it really wouldn't draw as much current as you think, no more than your computer really. And 24RMS is more than ehough power to push your stock speakers, probably 2x as much.
If you plan on upgrading your speakers you have more options, such as getting a 2 channel 100watt amp such as the one found here
http://cgi.ebay.com/ws/eBayISAPI.dll...710974044&rd=1
and then purchasing 2ohm stable speakers and wiring them in parallel to the amp, assuming the amp is 2ohm stable as well.
There are several options for you though.
I have heard of, but have never personally seen, an amp that pushes only 15watts per channel @4ohms, which would be perfect for pushing stock speakers.
