Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-27-2004, 10:30 AM   #1
crisr is on a distinguished road
Unhappy EPIA video + Winamp standby problem
Hi, all, I am building my setup using an EPIA V8000 board with Windows XP Pro SP1. When winamp is running (doesn't matter if it is playing, paused or stopped), upon resuming from standby or hibernate, the video driver (VIA's driver for EPIA-V) crashes and Windows defaults to the standard VGA driver. I have to reboot for the video to work fine again. When winamp is not running, the machine resumes from standby or hibernate just fine. I have tried Winamp 2.9 and then Winamp 5.3 and both cause this problem on resume... I have also tried numerous settings on winamp and BIOS to no avail...
Does anyone know about this issue between Winamp and VIA's video? Is there a solution / workaround, except having to quit winamp before standby?
crisr is offline   Reply With Quote
Advertisement Sponsored links
Old 08-14-2004, 06:58 PM   #2
Sick-B0y is on a distinguished road
I am having the same issue.. Let me know if you find a fix
Sick-B0y is offline   Reply With Quote
Old 08-14-2004, 07:17 PM   #3
adamis
Are you guys using any visualization studio stuff? I use to use milkdrop for some visuals but gave up on it because it was taxing the system to much and it usually messed up the system coming out of hibernation. I'm using an Epia 9000 with win2k and the original via video drivers.
adamis is offline   Reply With Quote
Old 08-14-2004, 07:18 PM   #4
yes I am using milkdrop...I will try switching to something else
Old 08-14-2004, 07:30 PM   #5
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Must be some weird video adapter incompatibility. I have winamp on my comp with win xp pro sp2 and don't have any problems coming out of standby or hibernate. Oh, I do use a program though called PowerStrip to reset my timing for my PSone screen. Maybe you should load powerstrip on to control your screen res and color depth. It grabs control of the screen res and stuff after coming out of hibernate or standby.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 08-15-2004, 10:12 AM   #6
I don't use any visualization. The problem also happens regardless of the skin. Right now I am using this workaround: I use Girder to detect standby/hibernate and close winamp before it, and then run winamp again on resume... It's a kludge, but it works...
Old 08-15-2004, 11:46 AM   #7
Tidder's Avatar
One of you guys should try powerstrip just to see... i'd be interested.
Tidder
Try RevFE
Best Quote EVER!!
Old 08-25-2004, 07:16 PM   #8
Lightbulb Problem solved...
I don't know exactly what was that fixed the problem: At first I was using a small HD, to test things, install and remove apps, etc. When I bought the definitive HD, I did a fresh Windows XP SP1, installed the VIA video drivers from the site (I thought I had an EPIA-V, but it's actually an original EPIA), and installed Winamp 5.04 (previously I had Winamp 5.03). There is nothing on Winamp's update history that would solve the problem from 5.03 to 5.04, but now my system stands by and hibernates with winamp running without a hitch!
Serial GPS and Epia M9000 problem mp3oplecarrier GPS 2 07-19-2004 10:13 PM
FV24 wasted space on video out problem Mikesz General Hardware Discussion 7 02-22-2002 08:20 PM
video problem mp3edneon General Hardware Discussion 4 07-23-2001 01:30 PM
Problem with Jaton video 77 w/ TV out Dustin Haug Software & Software Development 1 04-21-2001 08:58 AM
Video Card problem RaZor General Hardware Discussion 2 02-13-2001 01:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
