I have had my MII 10000 for a while now and no problems. I have found that one of the best solutions is to make sure your software is set up right before you start using it. Here is the process I use on setting up a system. It seems to work the best and have had very little problems.
Fresh install Windows, as soon as its done load drivers in this order:
Motherboard Chipset Drivers
IDE or Raid Drivers
Video
Sound
Modem / NIC
and then any other drivers
Making sure that you restart windows after everyone, Also make sure you are using the newest drivers off of the manufactures website.
After you are done with the drivers, Run windows update to make sure you have the newest updates for your OS.
I normally then like using the system for a while like this before installing any new programs to make sure the system is stable, then install other software.
It could very well be the hardware, I have seen many memory related problems with cheap memory, sometimes its hard to tell unless you have other hardware to test it with the motherboard.
