Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-13-2000, 03:46 PM   #1
Registered User
grandamp3
Question Where does ground loop isolator install?
Ok, i know that buzzing noise from inverter problems are the most talked about problems on here, but my question is how exactly does a ground loop isolator install? does it install in the cig lighter, does it install on the battery, does it install on the sound car feed, what? I havent gone to radio shack and looked yet because I have a busy schedule, but wanted to know before I went down there. In my system, the buzz isnt bad, can only hear it when I have my music up loud enough and theres a pause in the music so its something I can live with for a lil while, but probably wanna get it fixed before too long. Any info you can give me would be great.
Grand Am-P3
The Grand aMP3 Project
Car: 96 Pontiac Grand Am
Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
grandamp3 is offline   Reply With Quote
Advertisement Sponsored links
Old 09-13-2000, 05:12 PM   #2
Kain101
Post
The ground loop isolator normally installs on the positve wire of the head unit, the device then has another wire which is to be grounded,
----ground---
++++GLI<
++++head unit+++
hopefully that helps.
Kain101 is offline   Reply With Quote
Old 09-13-2000, 05:20 PM   #3
Registered User
mp31500
Post
You are thinking of a power line noise filter. A GLI is placed between the computer and the headunit on the sound supply line. At least the two I tried went there. I took them back. It did remove the whine but it also killed the sound qualty. It sounded like I was in an auditorium.
mp31500 is offline   Reply With Quote
Old 09-13-2000, 06:59 PM   #4
Registered User
grandamp3
Post
mp3wrangler>
So does the Ground Loop Isolator plug in like a 1/8" stereo plug or what?
Grand Am-P3
Old 09-13-2000, 10:08 PM   #5
AVGeek
Post
A ground loop isolator is a transformer that decouples the audio signal from source and destination. It would be best to install the transformer end closest to the head unit or amplifier, as noise that is picked up between the output of the sound card and the input of the sound system would be removed. If the transformer is closer to the soundcard, noise can be picked up between it and the audio system, and amplified. The Radio Shack model comes with a 1/8" to dual RCA adapter.
http://avgeek.mp3car.com
KG6OQD
www.americansandassociation.org
AVGeek is offline   Reply With Quote
Old 09-13-2000, 10:18 PM   #6
Registered User
grandamp3
Post
so basically ill have to get this device that converts 1/8 to RCA and then get another that converts from RCA female to 1/8 stereo? the reason being for now im using a tape adaptor because i have stock stereo and dont want to change over
Thanks,
Grand Am-P3
Old 09-14-2000, 09:10 AM   #7
AVGeek
Post
Actually, you'll just need to get one 1/8" to RCA adapter to convert back to your tape adapter.
KG6OQD
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
