The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 08-10-2004, 03:05 PM   #1
Triad.:'s Avatar
My Photos: (0)
anyone know of something like this?
I was browsing around and came across this.
http://www.turboxs.com/Dtec/dtec.shtml
I was just wondering if anyone knew of something similar to this system? I would be wanting a 'brain' unit (like the GBA) that outputs to a LCD (via composite, VGA, etc). The idea of it would be to make a custom dash LCD...
Triad.: is offline   Reply With Quote
Sponsored Links
Old 08-10-2004, 03:41 PM   #2
Vehicle: 1991 Nissan 300zx
My Photos: (0)
check the OBDII forum
software for custom guages, etc.
Kefka_Killer.owns(you);
kefka_killer is offline   Reply With Quote
Old 08-10-2004, 05:33 PM   #3
Triad.:'s Avatar
My Photos: (0)
I appriciate your link. One problem. I was thinking more along the lines of sensors actually detecting everything (water temp, EGT, fuel pressure, boost, etc).
The reason for this? My car is not OBD-II compliant.
edit: I just saw that my description wasn't the worded the best... I mean I want to hook up individual sensors to detect certain things, feed into some sort of box, and then output to a LCD
similar to Defi's (the company) Control Unit.
Old 08-11-2004, 11:53 PM   #4
Triad.:'s Avatar
My Photos: (0)
anyone?
Old 08-11-2004, 11:56 PM   #5
GWRedDragon's Avatar
Vehicle: 1991 Cadillac Sedan Deville
My Photos: (0)
http://www.phidgets.com ? That's basically a USB A/D converter, if you want to hook sensors up manually to your PC. If not, I'm not exactly sure what you mean.
GWRedDragon is offline   Reply With Quote
Old 08-12-2004, 12:35 AM   #6
darkhalo's Avatar
Vehicle: 2000 Honda S2000
My Photos: (0)
i wonder if that device actually uses the GBA for processing or just as a display.
After taking a closer look at the product you can only use it if you have a TurboXS UTEC Engine Management System. Which probably cost an arm and a leg
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
darkhalo is offline   Reply With Quote
Old 08-12-2004, 01:53 AM   #7
Triad.:'s Avatar
My Photos: (0)
The problem is I don't know how to code. I need something already programmed. I could manually attach all the sensors and things.
Ideally I want to create something like this ( http://www.stackltd.com/streetdash1.html ). Without the pricetag, and with a color LCD with programmable gauges.
Old 08-12-2004, 01:55 AM   #8
Triad.:'s Avatar
My Photos: (0)
I don't see where it says that. I believe it is saying you can use your GBA to tune the car in conjunction with the UTECH system if you have it. Otherwise, you can still use just a GBA + DTECH to display all the outputs.
Quote: Originally Posted by TurboXS website
If you own a TurboXS UTEC Engine Management System, the DTEC will allow you to leave your laptop at home and use your GBA for real-time fuel, boost, and ignition timing tuning. Please note that this feature will not be immediately available to DTEC users but will require a free future software upgrade available late 2004.
Old 08-12-2004, 07:14 PM   #9
Micco's Avatar
Vehicle: 2004 Infiniti G35 Coupe
My Photos: (0)
Check out LabView . It's a data acquisition suite that is graphically programmed. It's not cheap, but it would do what you want. Check that...it friggin expensive. But it will do what you want.
Micco is offline   Reply With Quote
Old 08-12-2004, 10:41 PM   #10
Triad.:'s Avatar
My Photos: (0)
ouch. That is quite the pretty penny. Thanks for the link though.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
