How do you plan on powering your car pc (inverter, opus, etc)?
[edit]
I have made an educated guess that you are planning on wiring your car pc using an inverter (please correct me if i am wrong). So what you could do is replace/move the inverter switch up to the front or use a relay to trigger it.
I have included some very basic schematics of how everything would be connected. Basically the carputer will only start when the key is in the ignition with the acc line is powered AND the switch you install is on.
Also I believe you will have to short the contacts the "on" contacts on your motherboard and/or set your bios to "Boot After Power Failure". Or something like that some other member may be able to help with this bit.
Also check the Schematics/Pin Outs/Diagrams Thread for some useful schematics!
[/edit]
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
