The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 08-18-2004, 03:09 PM   #1
My Photos: (0)
Opus remote trigger. Amp turn on
I there, i no dont have a head unit. My opus doesnt have a remote trigger as standard but ive found the point i need to solder onto, its just the delay is 42 seconds after the computer first gets power! Thats far too long. WHat are other options to turn on amp after a lesser time, say 10seconds.
cheers
Jamie
live2themaxuk is offline   Reply With Quote
Sponsored Links
Old 08-18-2004, 11:29 PM   #2
Raw Wave
rando's CarPC Specs
rando's Avatar
Vehicle: 2004 Toyota 4Runner
My Photos: (0)
You can just use a 12V output from your Opus. If you need a delay, you can build a simple RC circuit, or use a simple 555 timer based circuit. Alternatively, you can hook your amp-turn on lead to your serial port through a simple switching transistor. This will allow you turn your amp on/off programmatically whenever you like.
I believe this has been discussed several times before. Did you try the search button?
2004 4runner
rando is offline   Reply With Quote
Old 08-19-2004, 02:18 AM   #3
My Photos: (0)
yeah, found a few solutions. Id live a turn on delay unit but id have to get it from th US of A. cant find any in UK. Shame oopus ain t adjustable
Old 08-19-2004, 04:20 AM   #4
Raw Wave
Confused's Avatar
Vehicle: Honda Prelude 2.2 VTEC / Ford Anglia 105E
My Photos: (0)
Put a wire from the 12V connection on the 4 pin molex through a relay hooked up to the ignition to the remote turn on on the amp
This will turn the amp on after the Opus has powered up, and when you turn off the ignition, it will turn the amp off. The other option (of hooking the 12V from the Opus direct to the amp) is that it will still "thud" when you shut down the PC, which the method above will avoid
(See attached image)
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 08-19-2004, 01:32 PM   #5
My Photos: (0)
COnfused = top man
have a buscuit, or a beer on me Ill give that a go tomorrow. SO i shouldnt get any probs with the Amp/PC coming ON simultaneously?
cheers
Jamie
Old 09-08-2004, 03:37 PM   #6
KaiTech's Avatar
My Photos: (0)
cheers
Jamie
You can also send it to Opus for a software change and just pay for the shipping...
I'll spout simplistic opinions for hours on end.
Ridicule anyone who disagrees with me,
and generally foster divisiveness,
cynicism and lower level of public dialog!
KaiTech is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Amp Remote Turn-on via PSU? bulgogi777 Car Audio 13 08-24-2004 10:58 PM
Turn on Lilliput with OPUS? MaddSkillz LCD/Display 11 07-07-2004 12:42 PM
FS: Opus 90watt with Remote Trigger naevity Classified Archive 3 03-29-2004 04:47 PM
remote turn on lead from headunit to power up PC BluCivic93 General Hardware Discussion 3 07-27-2000 02:13 PM
amp turn on jasmar General Hardware Discussion 2 07-21-2000 08:51 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
