Hey guy,
I have an Xbox modified and setup in my 2k3 maxima.
here is the weblink
http://members.cardomain.com/minirx07
POWER:
Here is what i did, if you use the invertor, you will have to manually switch it on and off each time you turn of the xbox. If you use the cigerette lighter, when you start your car, your xbox will die.
I have the PERFECT solution for this, and my invertor and xbox is automated.
Right now the way it works, is my invertor is turned on by the ignition, but it also stays on during start, but with the key off, it shuts down the invertor.
How is this done? OKay, you have two + wires from your key, one is accessory, ignition on, etc, the other stays positive during crank. You need to add a diode on each line and run the wires to the trunk. From there you tie the two wires together and run it to a relay (diodes is to prevent feedback). The relay inturn will switch your invertor on and off (leave the invertor on the on position).
NOW FOR THE POWER SWITCH,
I leave my xbox in the trunk and i never go back there EVER. What i did was use a USB cable hacked and run it from the trunk to the dash. The wiring is straight forward. You need to open your xbox up, there is a tutorial at
www.xbox-scene.com on hacking the power switch to a controller, but instead you are just adding a 2nd power switch. The rest of the wires in the controller i used to supply an IR port to the front dash and control my xbox via my 2k3 Maxima's steering wheel interface or the DVD remote.
See my website.
Any more questions, don't hesitate to ask.
ED
