The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Search this Thread Display Modes
Old 07-16-2005, 11:07 PM   #46
Hark's Avatar
Vehicle: 2000 BMW 328Ci (E46)
My Photos: (0)
(cough) http://www.mp3car.com/vbulletin/frodoplayer/40730-volume-problem.html (cough)
Hark is offline   Reply With Quote
Sponsored Links
Old 07-17-2005, 11:56 AM   #47
Vehicle: 2004 BMW 330
My Photos: (0)
Hark, thanks for going easy on me Going to try this today.
I also noticed last night that when the ibus com program was running, frodoplayer was acting real slow and my music videos started to lag. It seemed like it was pulling CPU power like crazy. It was like it was working extra hard or trying to interpret lots of commands, though I am not sure how to trouble shoot. My CPU froze up a few times. I stopped running IBUC com and everything works fine. I rand teh IBUS Analyser just for giggles. I set it to COM1 and man, there were a lot of signals comming through the analyser....then it freezes. Does thi mean anything? I really want to get this to work as I am sooooo close.
My BMW 2004 330i
jedi7001 is offline   Reply With Quote
Old 07-17-2005, 10:05 PM   #48
Hark's Avatar
My Photos: (0)
Haven't seen this happen - there is a lot of messages that go through the bus, but it shouldn't drag you down. Let me know if you don't make any headway and I'll upload my ini file as well (not sure if it's different or not, but I know it's working for me).
Old 07-17-2005, 10:06 PM   #49
Hark's Avatar
My Photos: (0)
Here's another question - how can I make the SW volume buttons be the volume control for everything, regardless of the app I'm in? When my GPS screen (Copilot 8) is up, I'd still like the ability to control the volume - but it doesn't appear to let me until the focus is changed back to Frodo.
Old 07-20-2005, 12:08 PM   #50
Hark's Avatar
My Photos: (0)
bump - there must be a way to do this, since some keyboards have volume keys that affect the volume regardless of which app has focus. Anyone?
Sponsored Links
Old 07-20-2005, 12:12 PM   #51
Hark's Avatar
My Photos: (0)
Quote: Originally Posted by ftouanen
Download the 1.0.20 version and read the IBuscomM.ini. You will see a new parameter AppClassSendEventTo you can use instead off AppCaptionSendEventTo. This makes IBuscomm to search the window on the class, not on the title.
Example for WinAmp 2.81 :
AppClassSendEventTo="Winamp v1.x"
Hi Ftouanen - any way to make the ibuscomm not a task on the taskbar, such that when you alt-tab it doesn't appear as one of the window choices? The GPS software I'm using (Copilot) doesn't embed very well in other front ends, and I'm using the "alt-tab" app to switch between music and GPS - but it also brings up the ibuscomm app, which is a pain. I still want it to be active, just not visible.
Old 07-23-2005, 04:39 PM   #52
My Photos: (0)
IBUS Help needed
Im just finishing up my carpc install in my e46 touring, and ive been trying to get my Ibus interface to work that i got from resler. Ive run and tested ibuscomm with cdrskulls settings for roadrunner and it interacts with rr, but when i press the steering wheel buttons nothing happens and there is no message in ibuscomm. Im thinking maybe i have the wrong kind of cable from the interface to my epia board. Im using a normal com extension.
Do i need a crosswired cable or something? thanks for any help.
Marcus
marschwa is offline   Reply With Quote
Old 09-08-2005, 04:32 PM   #53
Vehicle: BMW 5 Touring 2002 NAV/TV
My Photos: (0)
It is already done !
Have a look in IbusComm.ini
[Settings]
; IBusComm can be totally invisible by setting Setvisible=False
SetVisible=False <= will do what you want
ftouanen is offline   Reply With Quote
Old 09-18-2005, 10:50 PM   #54
My Photos: (0)
So ibuscomm is set up to route i-bus messages directly into one application.
Is there any way to get ibuscomm to send the commands to windows for whatever application has focus?
Thanks,
Paul
pkarmouche is offline   Reply With Quote
Old 09-19-2005, 01:26 PM   #55
JPuma's Avatar
Vehicle: 2001 BMW X5
My Photos: (0)
yes, just rem out the AppClassSendEventTo="" line and it will work in whatever app is in focus, including your desktop.
JPuma is offline   Reply With Quote
Old 11-26-2005, 04:41 PM   #56
Hark's Avatar
My Photos: (0)
Sorry to revive this, but...
I haven't been able to get IbusComm to control Centrafuse. I've tried setting the AppClassSendEvnetTo="centrafuse", and I've also tried to rem it out completely, but nothing seems to work. I can see the sw button presses actions occur, but it doesn't affect centrafuse. The CF hot keys are set to "CTRL-ALT-UP", for example, for the volume up keys (they are set like this by default in CF).
I've got the IBuscomm.ini file actions set to "^%{UP}" for the volume up, with the rest set similar to this. Anybody have any ideas?
Old 11-26-2005, 05:05 PM   #57
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
does CF accept any other sdk commands at all, you could adopt the source to suit your needs like I did for RR. If you can point me to some info I would be happy to help
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 12-11-2005, 11:37 PM   #58
vinzer's Avatar
Vehicle: BMW X5 2001
My Photos: (0)
Does anyone tried all this with RR ? If yes than would you be pleased to post your ini files. Thank you
vinzer is offline   Reply With Quote
Old 12-12-2005, 12:07 AM   #59
Mattkins99's Avatar
Vehicle: '01 Lemans Blue M5
My Photos: (0)
this app works with RR as is.
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
Mattkins99 is offline   Reply With Quote
Old 12-12-2005, 04:55 PM   #60
vinzer's Avatar
My Photos: (0)
Thank you
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Solved: USB bus stays powered after shutdown S4Per Power Supplies 19 05-28-2007 09:09 PM
03 BMW 330i Dinan S3 Project fattytl Show off your project 29 09-27-2005 10:24 PM
What cable do you use to connect from sound card to Amp?....need answer fast... phatrabbitzz Car Audio 1 07-28-2004 10:26 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 02:16 AM
BMW TFT Sharp LQ065T9BR52 - how to connect? tsingsu LCD/Display 2 05-31-2002 09:59 AM
Sponsored Links
Ad Management by RedTyger
