The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 08-23-2004, 02:45 AM   #1
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
BMW I-Bus How to connect..
After asking about and searching everywhere.. I can confirm I have now connected the steering wheel buttons to my PC and they work 100%.. all the time everytime.. :-) Its awesome..
heres how.
First you need a I-Bus interface. I got mine in 'kit' form from HERE
It cost 30 euros.. (about £20) which is a bargin I thought..
Then was the hard bit.. trying to locate some software to map keys. I searched and searched and was getting prepared for a long month of learning and programming to write one my self then I came across some software called beboxMP. This is a piece of software wrote as a winamp skin.. Not what I was looking for, but it also included the IbuscomM app I was looking for :-) with a few changes to the ini file.. The job was done.
The changes I made were to change to com 2 as this was what I was using.. I also set the timeout to 0. I dont want the ibus to time out.. unsure if this was/is correct but it works. Then I changed the following line from/to
;AppCaptionSendEventTo="<* BeBoX Multimedia Player *>"
to
AppCaptionSendEventTo="MEDIACAR"
and also set
ProcessEvents=false
to
ProcessEvents=true
I then needed to find the correct values for the rest of the steering wheel buttons.. these worked out as follows
vol_up = 50046832111F
vol_dn = 50046832101E
phone_dn = 5004C83B8027
RT = 5003C8019A
All you need to do is add a few lines now to the .ini and your done :-)
It makes the Carputer so much better to use to be honest.. full control of the volume is a must. I also mapped the up/down to curser up/down.. the RT key to 'enter' and the Phone button to the Esc key.. but you can map these to any buttons you want.. I'm using mediacar atm, but you can map it to anyone.
I have attached the file.. let me know if anyone needs help
http://www.extremeoc.co.uk/
Building a new car soon - check it out !
www.BluePC.co.uk Bolton PC Repair - New Business venture.. I need to earn some money :-)
CdRsKuLL is offline   Reply With Quote
Sponsored Links
Old 08-23-2004, 02:53 AM   #2
Vehicle: VW/Golf III GL
My Photos: (0)
hm very interesting now i only ned the bmw :P
Golf 3 CarPc Status
///////////////50%--------------/
PSU:Inverter
GPS:BT GPS
PC: Slim notebook with 10.4"touch, external DVD.
Dock for car is in production.
Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
erazor is offline   Reply With Quote
Old 08-23-2004, 04:30 AM   #3
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Hmmmmm, I just need a steering wheel with buttons.
wonder if I can get an E46 wheel on my E36. or an E36 with buttons.
Enforcer is offline   Reply With Quote
Old 08-23-2004, 09:38 AM   #4
Vehicle: 2003 Mazda Protege
My Photos: (0)
guess i'll have to spec my new MINI with the multi-function steering wheel now...
Nicholasp27 is offline   Reply With Quote
Old 08-23-2004, 09:46 AM   #5
Raw Wave
rando's CarPC Specs
rando's Avatar
Vehicle: 2004 Toyota 4Runner
My Photos: (0)
That is sweet!
2004 4runner
rando is offline   Reply With Quote
Old 08-23-2004, 10:40 AM   #6
Jackboot's Avatar
Vehicle: 2003 BMW M3
My Photos: (0)
WONDERFUL! A few questions though:
This is a serial connection eh? What if my GPS receiver is already serial?
When you buy the "kit" form do you have to do soldering etc yourself?
Where did you grab the IBUS wire in the trunk? Thanks!
Jackboot is offline   Reply With Quote
Old 08-23-2004, 11:34 AM   #7
FreeDrive Creator
CdRsKuLL's Avatar
My Photos: (5)
lo.. ok.. yep this is a serial connection.. I'm using a M10000 board.. so decided to use the extra one onboard... yep 'kit' form.. just a bit of soldering.. you can buy it already done but this is more expensive. and the Ibus wire.. is where the cd multichanger unit is in the trunk (boot).. it just pushs onto the connector.. no cutting needed :-)
cheers
Steve
CdrPro
Old 08-23-2004, 08:23 PM   #8
Vehicle: 2004 BMW 330
My Photos: (0)
cdrskull:
I have to hand it to you. this was the post of my dreams. It took me a while to find the guy that made the pre built IBUS controller, but finally did and ordered one. I bought the fully assembled controller (I think it was $40). I have been sitting on it for a month now trying to figure out how to get an app to map the keys. I was about to break open a c++ book and do it the hard way. To be honest, I was hoping gork would post somthing before that. anyway, thank you and thank you. I will let you know how it works. Just getting ready to start my install here in September. I will keep a log on my thread (posted below).
My BMW 2004 330i
jedi7001 is offline   Reply With Quote
Old 08-23-2004, 10:45 PM   #9
Jackboot's Avatar
My Photos: (0)
cheers
Steve
CdrPro
I also have an M10000 board but I'm already using the 1 serial connection for my Deluo GPS receiver! Any suggestions? I don't think it's possible to split a serial connection is it? What GPS receiver are you using? Is it USB?
Good to know it is plug and play as far as the connector goes...
Old 08-24-2004, 12:51 AM   #10
FreeDrive Creator
CdRsKuLL's Avatar
My Photos: (5)
If you look at your m10000 board you will find you have another com port on board, you just need to get the correct lead for it. I was going to buy the M12000 board thats just come out, but I dont think that has the extra com port needed..
thats what you need, you can get them almost anywhere.. :-) All I did was remove the backplate and hot glue the interface to my pc case i've made.
once the carpet bit is put back you will only see the first 2 inch's of the case, where I drilled some holes for the vent, and put a usb socket.. coz you never know when it might come in handy :-)
cheers
CdR
Sponsored Links
Old 08-24-2004, 12:53 AM   #11
FreeDrive Creator
CdRsKuLL's Avatar
My Photos: (5)
NEWSFLASH
I have found some other software to try.. I will let you know how this one goes..
UPDATE..
Well it works, but I think it would take alot of messing about to get it working right.. I'm happy at the mo using what I have..
If anyone else whats a try its http://www.pcremotecontrol.com
cheers
CdR
Old 09-09-2004, 05:46 PM   #12
wysocki's Avatar
Vehicle: 2002 Mercedes C230k coupe
My Photos: (0)
Outstanding sweetness, BUT!!! Does I-bus (or anything like it) work on a 2002 Mercedes C230k????
wysocki is offline   Reply With Quote
Old 09-12-2004, 12:49 PM   #13
My Photos: (0)
Hey, I posted a bunch of stuff on I-Bus forums and here but nobody responded, will the i-bus work on my e36? I know I dont have the buttons but I dont really care about that, the main thing Id like to acomplish is intercepting messages from the obc or/and sending them. Ps How do you even hook up that controler? ;>
Regards,
Tom
bmwperson is offline   Reply With Quote
Old 09-15-2004, 05:59 AM   #14
My Photos: (0)
Hi everyone
I too would like to know does the Rover 75 use the I-Bus system ? Its supposed to be the same as used on the BMW 3 series.
My Rover 75 is a 2000 year build so i would assume its much like a similar year 3 series, it has the screen ( small version ) head unit. navigation drive as i have seen used in the 3 series.
Also how would i connect the ibus controller/adaptor ?
Thank you
MGR Boy is offline   Reply With Quote
Old 11-19-2004, 10:32 AM   #15
Vehicle: E46 320i 2003
My Photos: (0)
hi,
Yes i need Help !
I understand how to get codes with the Ibus Interface but how can i map it to Mediacar ?
could you post your modified file in mediacar as exemple ?
grave is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Solved: USB bus stays powered after shutdown S4Per Power Supplies 19 05-28-2007 09:09 PM
03 BMW 330i Dinan S3 Project fattytl Show off your project 29 09-27-2005 10:24 PM
What cable do you use to connect from sound card to Amp?....need answer fast... phatrabbitzz Car Audio 1 07-28-2004 10:26 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 02:16 AM
BMW TFT Sharp LQ065T9BR52 - how to connect? tsingsu LCD/Display 2 05-31-2002 09:59 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
