Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-03-2004, 07:24 AM   #1
Konrad is on a distinguished road
Again DevCon with another problem
Ok, before you all write "Do A search". I did search, that's how I found the program devcon. But I have a problem not discussed before.
" devcon remove @usb\* " Removes all USB devices and " devcon rescan " rescans all devices.
That's working great, the problem is that I have 4 USB-devices on my CarPC and I just want the GPS-Mouse to be removed/reset.
Ok, I looked up the Hardware-ID (if that really is the hardware id) in the hardware properties:
USB\VID_0784&PID_1070&MI_00\6&1D3C9A3D&0&0000
Now I tried " devcon remove @usb\VID_0784&PID_1070&MI_00\6&1D3C9A3D&0&0000 " but that didn't work. DevCon always says "No device removed".
I don't want all the USB-devices removed just to reset the GPS-Mouse.
So I have two questions:
1) can I automate the appearing requesters so I don't have to click them (install automatically or choose driver manually, blablabla) ?
2) The most important question: How do I just restart the GPS-Mouse with DevCon ?
Konrad is offline   Reply With Quote
Old 09-03-2004, 08:32 AM   #2
Ok, I just found out that I had a typo in this one. If typed correctly it works as I described.
My first question is still not solved though:
Old 02-04-2005, 12:32 PM   #3
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
All you have to put in a batch file is these two lines
devcon disable *PID_1070
devcon enable *PID_1070
Then to automate it you can use girder and push a button on a remote or else you can do what i did was use the resume setting in frodoplayer to run the batch file everytime you resume from hibernate or standby.
All you really need to do is disable and enable them you don't have to remove the device therfore circumventing you driver intalling interaction problem
antimatter is offline   Reply With Quote
Old 02-04-2005, 07:59 PM   #4
C4M
C4M's Avatar
C4M is on a distinguished road
Devcon? OMFG - this is exactly what I have been looking for!
My GPS introduces noise somewhere on the motherboard, and it will be nice to be able to disable it when I'm not using it.
Thanks guys!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
C4M is offline   Reply With Quote
Media Car not responding... Lilliput problem? carpcnoobie MediaCar 3 09-01-2004 02:38 PM
Lilliput Powering On/Off problem masch LCD/Display 0 05-09-2004 12:55 PM
power on problem ??? help please anyone Pingo1969 Power Supplies 26 04-07-2004 08:47 AM
I can't connect my hard drives + fan problem haisook General Hardware Discussion 0 02-03-2004 10:42 PM
Annoying problem c-dawg General Hardware Discussion 1 07-22-2002 09:19 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
