The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 09-06-2004, 05:55 PM   #1
Vehicle: 2002 Toyota Celica GT-S
My Photos: (0)
Advice: GPS and Wifi placement in 02 Celica
About to start purchasing for my project. Have computer and LCD decided and most of the fabrication plans done. Computer is going in glovebox and for LCD, I am going to increase the size of the existing dash compartment and leave hatch intact, so LCD can be stealthed behind hatch door.
Still trying to decide on WiFi and GPS placement/purchases. Stealth is a very important to me. I don't want anything on my dash or any non-stealthed additions. I have read-and-read-and-read. General consensus seems to be both Wifi and GPS would work better with additional antennas.
Looking for any car-specific advice on Wifi, GPS purchases. Easily stealthable antennas. Stealth antenna placement... etc etc..
Unfortunately I don't have alot of room to try different configurations (antennas and such), as my accountant (wife) isn't going to allow this to be a PPP (perpetual-purchase-project). Any help would be greatly appreciated.
TheJack is offline   Reply With Quote
Sponsored Links
Old 09-06-2004, 06:26 PM   #2
Registered User
aoLhaTer's Avatar
Vehicle: 04 Infiniti G35 Coupe
My Photos: (0)
whenever dealing with antennas your best bet is to mount outside the car
i however didnt want to drill through my car so i have both my gps mouse and wifi antenna sitting on the rear window deck
aoLhaTer is offline   Reply With Quote
Old 09-06-2004, 06:44 PM   #3
blurp's Avatar
Vehicle: 2003 Chevy Impala LS
My Photos: (0)
I've got both of mine inside the dash above the center ducts. I've got a sapphire gps and a dlink dwl-120+. They are sitting side-by-side, but I forgot to take a picture of the GPS in there. By the way, they both work great. I can drive almost 300 feet from my house and still get wifi connection. The inside shell of the top of my dash is hard plastic, like most dashes made today. So the signals go right through. If it's metal up there on yours, you might have problems.
www.bradleyjacobs.com
There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
blurp is offline   Reply With Quote
Old 09-06-2004, 10:18 PM   #4
My Photos: (0)
Back in the older permanent in-car cell phone days, there were slender, "tape-like" antennas that you could just attach to the glass. Do antennas like that exist for Wifi?
Old 09-06-2004, 10:21 PM   #5
Avalerion's Avatar
Vehicle: 2006 Toyota Matrix XR
My Photos: (0)
Buy a PCI card for your board.
Take off the platic antenna... They usually screw off.
Go to ebay and buy a little antenna.
Search for 5db antenna and it comes with a 5-6ft wire.
Avalerion is offline   Reply With Quote
Old 09-06-2004, 10:41 PM   #6
ppgt94's Avatar
Vehicle: MKIV VW Jetta
My Photos: (0)
You may be able to do what I did with my gps receiver. I have it right underneath the read deck. It's just hard plastic underneath and I have it squeezed in between a crack. It works fine because above it is the rear window (no metal blocking). I'll post a picture tomorrow.
ppgt94 is offline   Reply With Quote
Old 09-06-2004, 11:21 PM   #7
My Photos: (0)
If I was going to try an external antenna. Would it work if it was hidden somewhere outside.. possibly in the lower bumper where fog lamps are... Like this?:
Old 09-06-2004, 11:54 PM   #8
Vehicle: 1994/Ford/Probe GT
My Photos: (0)
that would be ok for wifi but the gps should be in clear view of the sky with no metal obstructions... radiator and engine block would block about half the view of the sky for the gps antenna in that location.
Bobby Digital is offline   Reply With Quote
Old 09-07-2004, 12:40 AM   #9
My Photos: (0)
Would this placement of a 5db antenna be a noticeable increase above a Wifi adapter under the plastic dash?
Old 09-07-2004, 12:56 AM   #10
My Photos: (0)
probably, as the metal doors/firewall/roof will block more wifi signal than having an antenna outside... just common sense. Also, the 5db antenna instead of just the adapter is a boost in itself.
Sponsored Links
vB code is On
Trackbacks are Off
Its not GPS but if you have WiFi... archimense GPS 0 06-29-2004 12:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
