Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-09-2004, 12:11 PM   #1
skippy76's Avatar
skippy76 is on a distinguished road
USB FM Radio with RDS/RBDS
Now, before I begin I know there is a similar project being done at the moment. However, the poject that I'm looking at is intended to keep it simple.
So the project that I'm looking at (but need help with) is a FM Radio receiver that can be controlled over USB and also provide the RDS / RDBS data over the same USB connection to the PC.
I've been looking online and quite frankly it should not be too difficult to create a radio that can be controlled over USB (just like the D-Link), but also plan on trying to provide RDS.
Any thoughts? (or help and suggestions?)
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
skippy76 is offline   Reply With Quote
Old 09-09-2004, 12:16 PM   #2
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Why recreate the wheel?
The reason Seth has undertook the project was becasue that there was nothing available (with any decent reception)
So... you will have to build your own from scratch.
I would just wait on what seth produces, he is very close to prototyping
antimatter is offline   Reply With Quote
Old 09-09-2004, 12:41 PM   #3
Seth's Avatar
Seth is on a distinguished road
Hello skippy76
Even though I don't understand why you decided to create something like that now and with another identical project on development, I wish you good luck and I look forward to what you can provide.
If you need any help or advice PM me. I'll be happy to help if I can.
Seth is offline   Reply With Quote
Old 09-09-2004, 12:48 PM   #4
GWRedDragon's Avatar
GWRedDragon is on a distinguished road
The ghetto solution: Slap a phidget controller onto the button wires for a $10 walkman. Then again, in the ghetto they don't have RDS.
GWRedDragon is offline   Reply With Quote
Old 09-09-2004, 01:06 PM   #5
Raw Wave
rando's Avatar
rando is on a distinguished road
How will it be simpler than Seth's project?
2004 4runner
rando is offline   Reply With Quote
Old 09-09-2004, 06:55 PM   #6
skippy76's Avatar
Not sure how or if it will be simpler... that's why I thought I would take a look into it.
Seth: I will probably end up using your solution, however, your project got me interested in seeing what RDS deocders are out there.
06 Volvo XC90
Old 09-09-2004, 07:20 PM   #7
Raw Wave
rando's Avatar
ok, I was just wondering what you were wanting to do differently. You said you intend to keep it simple. IMHO, there is no simpler solution that what Seth is proposing. Essentially what he has done is found some suitable chips and will be connecting them directly to the m10k via their native bus. If the reception is good, then he will add a USB interface. I'm pretty sure that's exactly what you have in mind. Isn't it?
2004 4runner
Old 09-10-2004, 11:12 AM   #8
skippy76's Avatar
Sounds about right. Thanks for the info...
06 Volvo XC90
Old 11-22-2004, 01:38 PM   #9
madmangler's Avatar
madmangler is on a distinguished road
Skippy, if I read right, you were wanting to build a pure USB solution? That would be attactive since I believe Seth's project will use a the analog Line-In since the components they chose only produce analog audio data.
Seth, please correct me if I am wrong (I'd like to be).
madmangler is offline   Reply With Quote
Old 11-22-2004, 06:16 PM   #10
Raw Wave
rando's Avatar
You are right, there's no way around producing analog audio for AM/FM decoding. An A/D step will allow the audio data to travel over USB but just geting AM/FM decoding working reliably from within a car is challenging enough. The main problem is the tuner ICs that are available (and associated components) are not readily available in small quantities.
2004 4runner
USB FM Radio septicdeath Media Engine 36 11-05-2004 09:51 AM
D-Link USB FM Radio Kalle.se General Hardware Discussion 15 09-15-2004 04:24 AM
Anyone found a new set of drivers for the D Link USB FM Radio ? SAScooby General Hardware Discussion 0 08-20-2004 03:21 AM
What to do about usb FM radio D-Link discontinued... erains General Hardware Discussion 8 01-07-2004 09:11 AM
WTB: D-Link USB FM radio Stine161 Classified Archive 4 11-12-2002 08:02 AM
